Gusset Base Plate Connection Problem
I've assigned gusset base plate connections to all my column bases that have chevron braces attaching to it. 30 out of 40 connections were successfully assigned. For the other 10 connections, when I try to assign them it just says "No Connection could be assigned" in the information panel.
I've made sure that all my chevron brace members are set to "braces" on the ram elements spreadsheet. I've been experimenting with the model but have yet to find a solution. The majority of my columns are rotated with respect to the x axis due to the irregular shape of the building I'm dealing with, not sure if this could be part of the problem. However, I do have columns that are rotated and connections were successfully assigned.
I'm using the ram connection module within ram elements version 13.4.0.177.
Parents Reply Children
