Hi there,
I am trying to model a steel portal frame. It is 3 bays high and 2 bays wide.
On-site the beams are going to have a moment end plate connection to the columns and the columns will be a continuous member from top to bottom.
When I go to check capacities of members I get very different results depending on if I linked or not linked the entire structure. I believe I should link the columns, but not the beams?
Is someone able to provide an explanation as to what linking does and when to use, or not use it?
I have read that you link members if the member is continuous beyond a node and does not have a twist restraint. But if we go into the element to enter in restraints, we can add lateral restraint, but not a twist restraint. Say we use fly bracing at knees so we can get lateral and twist restraint, we should use a non linked model?
Any guidance or discussion on this, would be hugely appreciated.
Thank you
I hope this is attached properly.
I do believe they are changing the default unbraced length. But how can we later add a twist restraint? it seems like we can add a lateral restraint, which doesn't change the default unbraced length (I assumed it would have).
I also add that the bending moment is the same for both situations indicating that it is changing the default braced length. But why does it do this, and when is it appropriate to link or not link the members?
Thank you :)
