Hi, see below. Is there any way to offset the column in the direction perpendicular to the brace direction. It only gives me the option for a transversal offset (see what I highlighted in red), but I want a longitudinal offset (parallel to the column web or perpendicular to the brace direction). Only way I've found to do a longitudinal offset is by changing the column orientation to "longitudinal", but this will change to connection to a beam to column flange which definitely is not the intent.
Can we get offset in both directions added to standard column base plates as well? Sometimes we have gravity columns that require a corner base plate.
we have this condition quite often, especially when we're detailing near existing structures. would really like to see this option in connections module
