RAM Connection doesn't considers the stiffeners in the base plate calcs
When designing base plates connections I understand that if we use stiffeners we can reduce the base plate thickness, but in the software if we use the option "With stiffener plates", the calcs are not affected by this and the base plate remains with the same thickness.
Regards.
