Bentley Communities
Site
Search
User
Site
Search
User
Product Communities
RAM | STAAD | ADINA
RAM | STAAD Forum
PRIMARY LOAD CASE CAN ONLY BE ADDED IF SET NL COMMAND IS USED.
Sign In
State
Suggested Answer
Replies
Answers
1 answer
Subscribers
110 subscribers
Views
Users
0 members are here
Offline
SREEHARI NAIR
over 6 years ago
CAN ANY ONE GUIDE ME WHY WE ARE USING SET NL COMAND
0
Offline
Surojit Ghosh
Sat, Jul 1 2017 4:47 AM
The SET NL command is used in a multiple analysis run if the user wants to add more primary load cases after one analysis has been performed. Specifically, for those examples, which use the CHANGE command, if the user wants to add more primary load cases, the NL value should be set to the maximum number with the SET NL command. The program will then be able to set aside additional memory space for information to be added later.
For example, if you specify 50 primary load cases prior to Perform Analysis command and later you include another 50 primary load cases after the CHANGE command, you need to specify SET NL 100 (or more) command so that program allocates the extra space in memory to include additional number of load cases.
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Reject Answer
Cancel
0
Offline
SREEHARI NAIR
Sun, Jul 2 2017 1:14 AM
Thanks Suro It was helpful
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
