Hi all,
I'm having an issue trying to import a CAD file into RAM concept. Essentially lengths that should be 37,550 mm long are coming in at 933,000 mm (so factored up by around 25). I have set the plan dimensions unit to mm as below. Anyone able to help?
Can you send us the drawing file that causes this problem? Also, let me know what product and format the file is. (use advanced reply editor - insert media, or Secure File Upload)
I was able to correct the issue with another CAD program by setting the insertion units to mm, though I don't really know why it mattered or how you could do the same in draftsight.
saved files
NONAME_4.dxf
If you want to take it a step further make a new drawings in draftsight with one unit length line only (say 1000mm exactly) and see what is exported. The resulting dwg/dxf file will be short enough to evaluate better.
