converting slabs to feature solid
How can I convert a design what is created in structural to a design that contains feature solids or solids.
Purpose is that I can modified this converted design in microstation XM
    If you have a simple slab in MicroStation and you want to convert it to a Feature solid you can add a feature like a hole. This will convert the slab to a Feature Solid.  This will also work for profiles that were extruded. It will convert it to a feature extrusion. You can then delete the hole or other feature that was added and the remaining solid will be a Feature Solid Slab or Extrusion.
    I'm not sure if the Structural solid can be modified this way or not. I don't have the Structural software installed. If you could send me a simple test case I would be glad to try.
    Hope this helps,
    Bill
    This is a test
