I have asked this 5-6 years ago on this platform to no avail.I even opened a thicket and was told that the developers are looking at the issue, but now its been ages and i'm still experiencing the same issues on large models?
Please see attached .std file, its a typical model with only one type of plate element and column type. If you open the model you will see many plates with missing property, but these were all previously assigned on the graphic editor. Even if you select plate with missing property and assign all , save the file and reopen it you will still have many plates with missing property?
The above obviously don't happen on smaller models, but for larger model version SS6 is really unstable or unusable.
.std file
https://drive.google.com/open?id=0By6OZXncXf9KQ0QxZF8xd2tQMXc
It seems that this issue will be addressed in the upcoming STAAD.Pro release - STAAD.Pro CONNECT Edition.
Thank you for your response, but what do you mean by connect edition? Could you be more specific, what build number will this CONNECT Edition have? or are you all together referring to a new product line?
The current version of STAAD, STAAD.Pro V8i SS6, Build 20.07.11.90 dated 30 March 2017, doesn't address the above issue.
The exact build number is not known yet. This will be a new version of STAAD.Pro. To the best of my knowledge, it should be released in a few weeks.
Thank you !
This issue is addressed in STAAD.Pro CONNECT Edition (version 21.00.00.57).
