Can the section wizard be used to determine the shear center of a built up section? I am evaluating an existing structure that has built-up columns (2 channels with a continuous plate on one side and laced on the other). I have made the built-up section in the Section Wizard but the properties do not appear to give the warping constant and shear center required to determine the compression strength in accordance with E4 of AISC specification.
Thanks!
These section properties are calculated in the Free Sketch mode of the Section Wizard, but not in the Section Builder mode.
