Dear Sir,
Can I made model of bridge connection with splice plate and gusset plate as in figure 1.
and all with gusset plate as in figure 2. (see my attchment) with RAM Connection? Thanks a lot.
PDF
At this point Ram Connection only supports gusset plate connections that fit the Column - Beam - Brace template. Other kinds of truss connections with multiple diagonals can't really be designed, though some users are using a standard CBB joint and checking bolts group capacity on individual members (as braces).
