How does one create and move custom Ram connection templates into the Staad Pro interface?
I found an article on the Bentley site that describes adding to the connnections.ini file, but the end of the article states
that this doesn't work beyond Select Series 6.
Steve Seaton
Users can create custom connection in RAM Connection module in the latest STAAD.Pro version - CONNECT Edition. Some more information is available in the Help of STAAD.Pro CONNECT Edition: Home > Design > Steel Design > Steel Connection Design > Connection Design workflow > Using the RAM Connection mode > Custom Connection Templates.
