How to design various connections for Built up tapered variable depth sections in RAM connection, as per IS or other codes if possible.
Open RAM Connection Help and type 'tapered' in the search field. This will find you a chapter "Allowable member types per connections" which lists what kind of sections can be used for each connection type for each design code.
