What Does it means cannot creata ism interface 6.0? Somebody known about it.
Install the latest Structural Synchronizer. communities.bentley.com/.../how-can-i-find-the-ism-installer
I found this on website,
RAM Elements users who utilize ISM should avoid upgrading to ISM 6.0, as RAM Elements is compatible only with ISM 5.0 or earlier. An update to RAM Elements that is compatible with ISM 6.0 is currently in development.
https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/32262/what-s-new-in-ism-6-0
where can I download ISM 5.0 ? ...Is it correct?
Roberto David Pérez Leon, CEE
That was true for Ram Elements V8i (v13.XX), but now that Ram Elements CONNECT Edition (v14.00) is out, it is compatible with ISM 6.0. I'll update the wiki.
OK thank you Seth.
RAM Elements 14.00.00.240
Structural Synchronizer 10.02.00.140
Attempting to create Repository with a model originally created in Ram Elements v8i 13.4.1.208. I recieve the error "Could not create ism interface 6.0"
Any help would be much appreciated. Thank you.
