What Does it means cannot creata ism interface 6.0? Somebody known about it.
Uninstalled each program, including ISM for Revit. Re-started computer. Made sure I had all the latest versions of each and re-installed - Elements, Synchronizer, ISM. Re-started computer.
Same result.
I assume these versions:
Ram Elements 14.00.01.08 (32 bit); Synchronizer 10.02.00.140 (64 bit)
Test 1, if you open Synchronizer and view one of the installed samples, does it open correctly?
Test 2, with any other ISM enabled application (e.g. Revit) are you able to create a repository?
I had one case recently where the Structural Property Catalog server (SPC Server) had to be uninstalled before reinstalling Synchronizer if that's any help.
Test 1 - Passed - I could open an installed sample.
Test 2 - Failed.
Uninstalled Structural Synchronizer and SPC server - then reinstalled.
Same result. Test 1 good Test 2 fail.
I am using RAM Elements 14.00.00.240
I put in a service request on your behalf (7000732084). Steve here is the resident expert and should be back in the office tomorrow to help troubleshoot. I assume you are still with SZS?
Yes - SZS,
Thank you
