I have a group of beams where I would like to replace node A with node B and vice versa. Now, I have to go to each beam and change each one separately. I hope there is a easier way? Thanks.
Please select all the beams and go to Tools > Redefine Incidence > Switch Incidence of Selected Beams
Thanks. I'm using STAAD.pro connect edition and I can't find "Redefine Incidence" in the search box?
In Connect Edition, the option is available within Utilities > Beam Tools > Redefine Incidence
Answer Verified By: James Froggett
Thanks. Just to add a point - it's called beam incidence. It worked great.
just to confirm, start node is A, and end node is B right
