I have a beam between two columns. There is a node between the supports. Now one of these beams is designed another one is not getting designed. If this problem is related to ENSH RENSH specification.somebody may pls explain the procedure as to how to specify these parameters with example.
Vijayarathnam
Port Blair, Andaman
Please attach that STAAD.Pro model if possible.
Sorry, I do not see the attachment. Could you please reattach the model or simply copy/paste the input file from STAAD Editor?
