Sir/Madam,
I need some clarification on the beam design and deflection parameters defining in STAAD Pro.
In the model, I have used IS 800 (Limit state method) as the design code check.
My requirement is I want beam no. 83 , 84 & 81 to be considered as single beam in design checking .
So I defined beam no. 83 , 84 & 81 with LZ 2.5m and
For deflection check I defined beam no. 83 , 84 & 81 with DJ1 as 37 & DJ2 as 44.
Whether this way of defining is correct??
Consider beam no . 83
I have defined DFF as 325
Deflection length (dff) should be the distance between the defined nodes ( i.e here it should be between DJ1 & DJ2 defined ) but in the output file it is giving some other value ( 6817) ?? Whether my defining way is wrong ?
Pls. clarify and correct my defining parameters.
I have attached the model.
STAAD SPACE
START JOB INFORMATION
ENGINEER DATE 29-Sep-17
END JOB INFORMATION
INPUT WIDTH 79
UNIT METER KN
JOINT COORDINATES
1 0 0 0; 2 0 0 2.5; 3 2.5 0 0; 4 2.5 0 2.5; 5 0 4.3 0; 6 0 4.3 2.5;
7 2.5 4.3 0; 8 2.5 4.3 2.5; 9 0 8.6 0; 10 0 8.6 2.5; 11 2.5 8.6 0;
12 2.5 8.6 2.5; 13 0 8.6 1.25; 14 2.5 8.6 1.25; 15 1.25 8.6 0; 16 1.25 8.6 2.5;
17 1.25 4.3 0; 18 0 4.3 1.25; 19 1.25 4.3 2.5; 20 2.5 4.3 1.25; 21 0 10.975 0;
22 0 10.975 2.5; 23 2.5 10.975 0; 24 2.5 10.975 2.5; 37 0.5 10.975 0;
38 1 10.975 0; 39 1.5 10.975 0; 40 2 10.975 0; 41 2 10.975 2.5;
42 1.5 10.975 2.5; 43 1 10.975 2.5; 44 0.5 10.975 2.5; 45 0 10.975 2;
46 0 10.975 0.5; 47 2.5 10.975 2; 48 2.5 10.975 0.5; 49 0.5 10.975 0.5;
50 0.5 10.975 2; 51 2 10.975 0.5; 52 2 10.975 2; 53 1 10.975 0.5;
54 1.5 10.975 0.5; 55 1 10.975 2; 56 1.5 10.975 2;
MEMBER INCIDENCES
1 1 5; 2 2 6; 3 3 7; 4 4 8; 5 5 17; 6 7 20; 7 8 19; 8 6 18; 9 5 9; 10 6 10;
11 7 11; 12 8 12; 13 9 15; 14 11 14; 15 12 16; 16 10 13; 17 1 2; 18 2 4;
19 4 3; 20 1 3; 21 13 9; 22 14 12; 23 15 11; 24 16 10; 25 17 7; 26 18 5;
27 19 6; 28 20 8; 29 5 13; 30 13 6; 31 6 16; 32 16 8; 33 8 14; 34 14 7;
35 7 15; 36 15 5; 37 1 18; 38 18 2; 39 20 3; 40 20 4; 41 9 21; 42 10 22;
43 12 24; 44 11 23; 45 21 37; 46 24 47; 47 24 41; 48 22 45; 69 37 38; 70 38 39;
71 39 40; 72 40 23; 73 41 42; 74 42 43; 75 43 44; 76 44 22; 77 45 46; 78 46 21;
79 47 48; 80 48 23; 81 37 49; 82 40 51; 83 49 50; 84 50 44; 85 51 52; 86 52 41;
87 49 53; 88 50 55; 89 52 47; 90 51 48; 91 46 49; 92 45 50; 93 53 54; 94 54 51;
95 55 56; 96 56 52; 97 38 53; 98 39 54; 99 43 55; 100 42 56;
START USER TABLE
TABLE 1 COLUMN.UPT
END
DEFINE MATERIAL START
ISOTROPIC STEEL
E 2.05e+008
POISSON 0.3
DENSITY 76.8195
ALPHA 1.2e-005
DAMP 0.03
TYPE STEEL
STRENGTH FY 253200 FU 407800 RY 1.5 RT 1.2
END DEFINE MATERIAL
MEMBER PROPERTY INDIAN
45 TO 48 69 TO 100 TABLE ST ISMB400
5 TO 8 13 TO 28 TABLE ST ISMB250
29 TO 40 TABLE SD ISA150X150X10
1 TO 4 9 TO 12 41 TO 44 TABLE ST ISMB400
CONSTANTS
MATERIAL STEEL ALL
SUPPORTS
1 TO 4 FIXED
LOAD 1 LOADTYPE None TITLE LOAD CASE 1
MEMBER LOAD
83 85 87 88 93 TO 96 UNI GY -40
JOINT LOAD
21 TO 24 FY -20
FLOOR LOAD
YRANGE 0.2 4.3 FLOAD -7.5 GY
YRANGE 4.5 9 FLOAD -7.5 GY
YRANGE 12 15 FLOAD -7.5 GY
YRANGE 16 20 FLOAD -7.5 GY
SELFWEIGHT Y -1
PERFORM ANALYSIS PRINT STATICS CHECK
PARAMETER 1
CODE IS800 LSD
TRACK 2 ALL
LZ 2.5 MEMB 81 TO 86
LZ 2.5 MEMB 45 47 69 TO 76
LZ 1.5 MEMB 87 88 93 TO 96
DJ1 44 MEMB 81 83 84
DJ1 37 MEMB 81 83 84
DJ1 41 MEMB 82 85 86
DJ1 40 MEMB 82 85 86
DJ1 23 MEMB 45 69 TO 72
DJ1 21 MEMB 45 69 TO 72
DJ1 24 MEMB 47 73 TO 76
DJ1 22 MEMB 47 73 TO 76
DFF 325 ALL
MAIN -1 MEMB 29 TO 40
CHECK CODE ALL
FINISH
You are using only DJ1 parameters in your model, i.e.:
Change DJ1 to DJ2 for node 44 or 37 and see if you are getting the expected results. The same should be done to the other beams where the deflection check is being performed.
Thank you ...
I have changed your indicated parameter.
But i am unable to get the expected results .. pls. check the model.
Displacement of nodes 37 and 44 is 0.786 mm. This can be seen in the Nodes Displacement table. Maximum global deflection of beams 81, 83 and 84 is 1.275 mm. You can see it by double clicking on member 83 and going to Deflection tab. So the local deflection is 1.275 - (0.786 + 0.786)/2 = 0.489 mm.
Thank you for clear reply.
My other requirement is I want beam no. 83 , 84 & 81 to be considered as single beam in design checking .
So I defined beam no. 83 , 84 & 81 with LZ 2.5m .
Whether this parameter is correct and sufficient to check?
or any other paramter to be considered?
Sir,
Deflection part is now clear .Thank you
Pls. clarify other doudt ,
if i want beam no. 83 , 84 & 81 to be considered as single beam in design checking.
Pls.clarify this doudt .
waiting for your reply
Can anyone pls. help to clear the doudt ...
Based on your DJ1 and DJ2 & LZ specification for members 81 83 84 it is apparent that you want to consider the physical member to be spanning between nodes 37 and 44. Since you have beams modeled in orthogonal directions the default for LY and lateral torsional bucking parameters should hold good. So as far as I can see specifying DJ1, DJ2 and LZ should be fine.
Thank you sir....
I need one more clarification.
In the model i have changed column section to box column section ( section created in section wizard) where the column cross section axis is Y-Z. ( attached column cress section)
Now assigning this column section in STAAD model. what will be orientation axis of column. ( Since i am not able to view the 3d render of column , i have doudt how the column orientation will be assigned).
Can anyone pls. clarify the doudt
Plot the local axis of the column (SHFT+O). Check how the local Y and Z are oriented. You know the values of Iy and Iz too. So combining both information you can understand how the column is oriented. Use beta angles if you have to change the orientation.
i have seen the local axis but how to identify which column orientation . Where do i get the ly & lz values of column in STAAD ??
I am unable to get the column orientation .i have seen the local axis but how to identify which way column is oriented. Where do i get the ly & lz values of column in STAAD ??
