While importing the dxf, instead of choosing the No change, please choose Y Up
how to rotate the model sir to have a proper isometric orientation?
Instead of importing and then rotating the model, you should choose the Y-UP option during the import as I mentioned in my last post. This would automatically make the orientation correct.
Just for your information to rotate a model you need to select the members and go to the menu option Geometry > Rotate to specify the axis of rotation, amount of rotation.
what is the angle of rotation sir ?
The angle of rotation is the amount by which you are trying to rotate the structure about the chosen axis.
