Would it be viable to model Plates with out meshing instead of using floor load?
I have a complex beam arrangement in the floor with openings in that case it would take a lot of time to apply load as floor load since the co-ordinates will have to be defined. Instead of that would it be right to model plates & apply loads on it without meshing it. Also how can I mesh all the plates by selecting all plates & keeping the aspect ratio same.
