Looking for a way to change staad.pro to japanese language.
The STAAD.Pro Japanese language pack ( version 20.07.11.82 ) can be downloaded from connect.bentley.com ( same place from where you download STAAD.Pro )
Hi Sye, will the Japanese language pack version 20.07.11.82 also work with STAAD.Pro build 20.07.11.90?
Japanese language pack version works with STAAD.Pro build 20.07.11.82 only.
If we change the language to Japanese in STAAD Pro, aside from the user interface being changed to Japanese, will the reports/output file and Help also be translated to Japanese langugae? Thank you.
Answer Verified By: Bikash
Hello Gerard, STAAD.Pro Connect Edition U3 (22.03.00.28) has the Japanese version that could be downloaded from Bentley download site. You may select the language as Japanese from the drop down. In the said version: 1) GUI (major part) is displayed in Japanese 2) We only have implemented Readme and Physical Modeler Help in Japanese.
Readme - https://docs.bentley.com/LiveContent/web/STAAD.Pro%20Readme-v5/ja/readme_STAADPro.html Physical Modeler Help - https://docs.bentley.com/LiveContent/web/STAAD.Pro%20Physical%20Modeler-v9/ja/SPPM_INDEX.html
3) The output (ANL) is still in English. Best regards,BM
