How can I check the tributary area of floor load in each of the periphery beams around a slab panel ?
Yield Line theory is taken into account while applying floor load in staad. After the application of floor load the tributary area of each beam is visible. But, is there any option in Staad where I can check the load carried by each beam after applying floor load. Since, for irregular shaped slab panels it is very difficult to calculate tributary area manually after applying floor load it would be very helpful if I could get the numeric values of the tributary area of a beam from staad.
