Hi,I want to amend the density of concrete but I am at a loss of how to do so. The density within my file is currently around 24kN/m3 but I want to amend this to 25kN/m3 to be inline with Eurocode 1991. I have attempted to use the 'Density' command under 'Commands > Material Constants' but I get the following window when I try to input a value for 'the view' which is a large concrete slab.
Any help would be greatly appreciated.
Hi Kevin,
You can change the density in the Editor:
ISOTROPIC CONCRETE
E 2.17184e+007
POISSON 0.17
DENSITY 23.5615 - just change value to 25 and save.
ALPHA 5.5e-006
Answer Verified By: Kevin O'Donoghue
Thanks Andrej.
what if there are 2 material? how to separate the command?
Each material has its own name and material properties following after that name.
