Can I ask how to change the color of the selected member in staad connect edition, V8i before are in red color, now are in blank and if I want to make my working screen into blank color I'm not able to see already member that are selected because the member selection color was black.
Answer Verified By: IronMaxSteel
Hi Sye,
Thank you, but your suggestion did not work. Still my selection highlighted member still in blank color.
Please refer to the screenshot in my post. You need to click on the square beside the item "Selected Entities". It is showing as black in your case and that is why you are having the same issue.
Thank you
Thank you, yes now its working. But how to make all the set up color to be default? because when I created new project everything turns black again and need to set them up again.
