I am using Staad foundation advanced to design my piling foundation. However, I got a error message :" [ERROR] NO LOAD CASE INCLUDED IN THE JOB IS DEFINED AS 'DESIGN LOAD CASE'". Please let me know how to solve this issue. Thanks.
This means that none of the load cases that you have included as part of the job is an Ultimate load case or a Primary Load case. You can check on the type of a load by going to the Load and Factors and clicking on any load case. The Load Case type can be set from within the Load Description window below.
I have the exact same problem here, but although i have a load case defined as Ultimate i keep getting the same error.
Lucas : Check what load cases are included as part of the job. You may have defined an Ultimate Load case but it may not be part of the job.
I did! Both are part of the job and i keep getting the same error.
And before, I was using only one load case defined as primary, but i kept getting the error saying no load case was defined as service load case.
