Hi!
I am trying to model a deck on a set of roof beams. The joists in the grids extend beyond the enclosed beam grid. Is there a way I can model a deck, still having the RAM Steel Beam module to design the joists, instead of displaying "xxGSP" as the joist design?
Model short beams (of any material) between the tips of the cantilevers. Then model the slab edge out-board of those perimeter beams, Be aware that cantilevers on joists will also cause a special (SP) design case. See this for more: communities.bentley.com/.../ram-steel-joists-faq
Hey Seth!
Thank you for your prompt response. I have already tried the case you mentioned. But, like you have called out caution, that joist will now belong to a SP design case, I did encounter the "xxGSP" design. I would like to know how I can design the joists without specifying the depth.
You could eliminate the cantilevers altogether and simply use a large slab edge overhang. You'll get designs that way, though they could be unconservative.
