In the manual it says that steel grade list can be updated by editing section library. I need to add Steel grade according to Russian GOST characteristics. Could you please describe step by step how to edit the section library.
The section library contains the names of steel grades available for each section. When you choose a section you must also choose a steel grade from those available. You may change grade availability by editing the section library but only recognized grades should be used.
Item
US Grades*
Canadian Grades
UK/Eurocode Grades
Aust./NZ Grades†
Hot-rolled sections
A36, A588, A992
260W, 300W, 350W
S235, S275, S355, S450, S460, 43, 50, 55
250, 300, 350, 400
Welded sections
250, 300, 350, 400, 450, 300M
Hollow sections
A501, A500-B, A500-C, A53
300WH, 350W, 400W
C250, 345, C350, C450
Cleats, plates, stiffeners
A36, Gr.42, Gr.50
260W, 300W, 350W, 400W
250, 300, 350, 250+, 300+, 350+
Is it possible to create new list of Steel grades or do you have program file to add Russian Grades to the list?
The manual it says: "If you wish to include a grade that is not in the list you may define up to 10 user grades."
