Is it possible to import Ram Concept files into RAM SS? I would like to import the geometry of a floorplate and the supporting columns/wall locations.
Kind regards,
Katherine
In RAM Concept, click on File - Sync RAM Structural System - Export Geometry to RAM Structural System. After clicking on this menu option, a dialog will appear prompting you to select an existing .rss file or choose a name for a new .rss file. Then, the dialog below will appear. The Floor Type is used for the name of the Layout in RAM Modeler.
More on exporting geometry from RAM Concept to RAM Structural System can be found on the web page below:
https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/4334/ram-concept-ram-structural-system-integration-tn
Hi Karl I'm getting an error when I try to export geometry out of Ram Concept to Ram SS saying:
"An internal Error has occurred.
ABoundaryDef::outerPerimeter: boundary definition has no solid boundaries.
Please contact support"
Please can I get some help with this error?
Please share your model using the Secure File Upload link at the bottom of the page and then post the file name here after it is uploaded. I will review and see if I can track down the cause of the error.
Hi, When attempting to export geometry out of Ram Concept to Ram SS using an existing .rss file, my windows crashes. Is this a common error or is there something i can try to prevent the RAM concept from crashing?
