Dear All,
I wish Phyical Modeler in Staad Pro Connect Edition will going to have option for mesh refinement.
What I mean there is a certain area for example column post on a slab, which I want to refine the mesh in that point, As you know the more fine mesh the more accurate the result it will be right.
Another one, I wish also ISM can able to handle curve plates, which I think currently cannot.
Thank you
You are correct. Mesh refinement options will be added in future versions of the physical modeler. If you have a curved surface then ISM would not able to handle that but what you can do is, instead of defining the geometry as a single surface, break it down into a series of flat surfaces connected to each other and then you will be able to get the whole assembly exported to ISM.
Answer Verified By: IronMaxSteel
Hi Sye,
Thank you, regarding to curve plates... Im referring to BIM to ISM, it will not be nice to create in BIM a pointed curve as it will reflect in the drawings. I hope soonest ISM can able to do that.
