I cant find the option for staad foundation, where is the assign button? does at the bottom of the foundation design panel have button, but problem nothing to scroll down. the panel was fixed.
It seems that your screen resolution is too low. If you canot increase the screen resolution, try to turn on the AutoHide option for the ribbon and then see if STAAD Foundation Advanced button bocomes visible.
Answer Verified By: IronMaxSteel
Thank you Modestas, Its help by autohide the ribbon
Where is the option of autohide the ribbon?
Click on the arrow and pin sign to minimize the ribbon and workflow .
