Aluminium design is not working in CONNECT edition after the latest update. When I choose ASD 1994 for CODE (as per the reference) , the results in the output are for AISC 1989 and an error regarding Young`s modulus appears.
STAAD PLANE START JOB INFORMATION ENGINEER DATE 18-Dec-17 END JOB INFORMATION INPUT WIDTH 79 UNIT METER KN JOINT COORDINATES 1 0 0 0; 2 6 0 0; MEMBER INCIDENCES 1 1 2; DEFINE MATERIAL START ISOTROPIC ALUMINUM E 6.89476e+007 POISSON 0.33 DENSITY 26.6018 ALPHA 2.3e-005 DAMP 0.03 END DEFINE MATERIAL MEMBER PROPERTY ALUMINUM 1 TABLE ST WF(A-N)5X5.37 CONSTANTS MATERIAL ALUMINUM ALL SUPPORTS 1 2 PINNED LOAD 1 LOADTYPE Dead TITLE DL SELFWEIGHT Y -1 LOAD 2 LOADTYPE Live TITLE LL LOAD 3 LOADTYPE Temperature TITLE TEMP. LOAD COMBINATION 4 1 1.0 LOAD COMBINATION 5 1 1.0 2 1.0 3 1.0 LOAD COMBINATION 6 1 1.0 2 0.75 3 0.75 LOAD COMBINATION 7 1 1.0 2 0.75 LOAD COMBINATION 8 1 0.6 PERFORM ANALYSIS LOAD LIST 4 TO 8 PARAMETER 1 CODE ASD 1994 BEAM 1 ALL TRACK 4 ALL CHECK CODE ALUMINUM TAKE OFF ALL FINISH
TRACK command gives more options but they are not visible. You can not read the description.
Quick response will be highly appreciated. I need to be able to complete the task at hand ASAP.
When I click on it from the drop down list it becomes CODE ASD 1994
This should be changed.
And do you know what are the options of the TRACK command that are unreadable?
I added all of those parameters but still got the same message.
**IN TABLES 3.3-1 and 3.3-2, NO DATA IS AVAILABLE FOR THE FOLLOWING COMBINATION FOR MEMBER # 1 **
TRACK options are described in the chapter 1H.3 Design Parameters in STAAD.pro Help.
Thank you very much.
But it really should be clear while working with the software itself.
