Example for RAM.zip
Dear Concerned,I have attempted to use the following link attached by RAM Concept team to extract tendon Profile into a Tabular Format.However many tendons are missing from the extracted Table. Please find attached the following example and result. I have done extensive testing and it seems the bug is in the significant figures, Tables extracted from RAM-Concept have 4 significant figures, while DXF Files tend to have a significantly larger amount of significant figures these could be the source of error causing the code to mess up some tendons not to be extracted.https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/35950/export-ram-concept-pt-tabular-dataAlso Besides the earlier referenced procedure, is there a way I can export tendon profile in 3D from RAM Concept to a DXF/DWG file, (Maybe from a standard perspective view, if we can export to 3D DXF), it has been requested multiple times since as back as 2010, https://communities.bentley.com/products/ram-staad/f/ram-staad-forum/54875/profile-points-tendons-in-ram-concept.Is there a plan to add this functionality, it would be very useful for Review, clash detection, coordination with other software and/or to produce shop drawings.Thank you,Regards
Wentao,
Upon further review, it looks like the utility tool is ignoring shorter tendons (the highlighted tendons were not included in the excel output).
-Nathan
Nathan,
I suspect, it does have something to do with close clustering of the items and the tolerance.
Please send through files wentao.zhang@bentley.com and I will investigate.
Kind Regards,
Wentao Zhang
