Dear Concerned, Is there a way to import Tendons into RAM Concept or to manipulate data information using a readable form of Data similar to the GCFF File,Also is RAM Concept VBA compatible, this will also allow us to quickly modify Slabs, Frames, Columns or Tendons, Or even to extract Data, we are mainly concerned with tendonsThank you
Regretfully no, tendon objects cannot be created through the GCFF file interface at this time and there is no application programmer's interface (API) to edit the data more directly. It's come up before but never to the top of the backlog.
Answer Verified By: Carl Abinader
That Is unfortunate, However please let us know once the API will be implemented, it'll be of great help for large projects.
Is there any way to handle RAM Concept by Codes?
A python-based scripting API with some read-in and write-out capabilities will be available in RAM Concept Version 8 Update 2, which is scheduled to be released in the upcoming months. If you are interested in previewing that feature in a Beta release, please send me a private message.
Karl,
How do we use this feature? I would like to import reactions from RAM elements model into Concept to design matt foundations.
I am not a programmer so do you have any shortcuts to help with this?
Thanks for all the help.
