How to get to know the force that cause the beam shrinkage using the STRAIN load definition?
I'am trying to test the Strain Load Definition on staad.
I assign -0.002m on the Strain load definition in staad pro and run the analysis, but I could get any result from the post processing, all forces result are in zero values. Because I wanted to know how much axial force that the strain cause.
Thank you in advanced.
