RAM Frame Reactions for an "Elevated Building"
I am designing the top level of a structure. I modeled a dummy structure below to ensure I was getting the correct wind loads. I need to get the reactions from my top level on the structure below. Using the reaction envelope feature doesn't work because this only gives reactions at the base level. Is there any way to see the reactions I'm looking for without having to look at the member forces and then calculate the resulting reactions?
Thank you.
Parents Reply Children
