LOAD COMBINATION OF ENVELOPE CASES
Hi all,
I am having a moving load generation which create hundreds of load cases. As a results, I have to create a lot of load combinations/ repeat loads, this slows down the analysis tremendously.
I wonder that can we create a envelope of all the load cases created by moving load generation and then use this envelope in other load combination. Any suggestion to workaround with this situation in Staad Pro. Thank you very much for your advice.
Parents Reply Children
