STAAD SPACESTART JOB INFORMATIONENGINEER DATE 12/23/2017JOB NAME STG IPBDJOB NO C-2348JOB REV 00JOB PART TYPE-AENGINEER NAME DINESHCHECKER NAME DINESHCHECKER DATE 12/23/2017END JOB INFORMATIONINPUT WIDTH 79UNIT METER KGJOINT COORDINATES2 0 1.39 0; 4 6.40001 1.39 0; 5 0 1.29 0; 6 6.40001 1.29 0;MEMBER INCIDENCES1 2 5; 2 2 4; 3 4 6;DEFINE MATERIAL STARTISOTROPIC STEELE 2.03889e+010POISSON 0.3DENSITY 7833.37ALPHA 6e-006DAMP 0.03TYPE STEELSTRENGTH FY 2.53104e+007 FU 4.07779e+007 RY 1.5 RT 1.2END DEFINE MATERIALMEMBER PROPERTY INDIAN1 TO 3 TABLE D ISMC150 SP 0.05CONSTANTSMATERIAL STEEL ALLSUPPORTS5 6 FIXEDDEFINE IBC 2012SS 0.57373 S1 0.18733 I 1.5 RX 3 RZ 4 SCLASS 4 TL 12MEMBER WEIGHT2 CON 356 2.12 CON 356 3.22 CON 356 4.3***********************************************************************LOAD 1 LOADTYPE Seismic TITLE EQ XIBC LOAD X 1PERFORM ANALYSISCHANGE*************************************LOAD 2 LOADTYPE Seismic TITLE EQ-XIBC LOAD X -1PERFORM ANALYSISCHANGE****************************************LOAD 3 LOADTYPE Seismic TITLE EQZIBC LOAD Z 1PERFORM ANALYSISCHANGE*****************************************LOAD 4 LOADTYPE Seismic TITLE EQ-ZIBC LOAD Z -1PERFORM ANALYSISCHANGE***************************************LOAD 5 LOADTYPE Dead TITLE DLSELFWEIGHT Y -1 MEMBER LOAD2 CON GY -356 2.12 CON GY -356 3.22 CON GY -356 4.3**************************************LOAD 6 LOADTYPE Live REDUCIBLE TITLE LLMEMBER LOAD2 CON GY -100 3.2****************************************LOAD 7 LOADTYPE None TITLE SCFMEMBER LOAD2 CON GX 149 3.2*******************************************-----FACTORED LOAD COMBINATIONS (SEC. 203.3.1)---------***LOAD COMB 101 1.4DL5 1.4 LOAD COMB 102 1.2DL+1.6LL5 1.2 6 1.6 LOAD COMB 103 1.2DL+1.0LL5 1.2 6 1.0 LOAD COMB 104 1.2DL+1.0LL5 1.2 6 1.0 LOAD COMB 105 1.2DL+1.0EQX+1.0LL5 1.2 1 1.0 6 1.0 LOAD COMB 106 1.2DL+1.0EQ-X+1.0LL5 1.2 2 1.0 6 1.0 LOAD COMB 107 1.2DL+1.0EQZ+1.0LL5 1.2 3 1.0 6 1.0 LOAD COMB 108 1.2DL+1.0EQ-Z+1.0LL5 1.2 4 1.0 6 1.0 LOAD COMB 109 0.9DL+1.0EQ+X5 0.9 1 1.0 LOAD COMB 110 0.9DL+1.0EQ-X5 0.9 2 1.0 LOAD COMB 111 0.9DL+1.0EQ+Z5 0.9 3 1.0 LOAD COMB 112 0.9DL+1.0EQ-Z5 0.9 4 1.0 *****-----SERVICE LOAD COMBINATIONS (SEC. 203.4.2)---------***LOAD COMB 201 1.0DL5 1.0 LOAD COMB 202 1.0DL+1.0LL5 1.0 6 1.0 LOAD COMB 203 1.0DL+0.7EQX+1.0LL5 1.0 1 0.7 6 1.0 LOAD COMB 204 1.0DL+0.7EQ-X+1.0LL5 1.0 2 0.7 6 1.0 LOAD COMB 205 1.0DL+0.7EQZ+1.0LL5 1.0 3 0.7 6 1.0 LOAD COMB 206 1.0DL+0.7EQ-Z+1.0LL5 1.0 4 0.7 6 1.0 LOAD COMB 207 1.0DL+0.75LL+0.75(0.75EQX)5 1.0 6 0.75 1 0.75 LOAD COMB 208 1.0DL+0.75LL+0.75(0.75EQ-X)5 1.0 6 0.75 2 0.75 LOAD COMB 209 1.0DL+0.75LL+0.75(0.75EQZ)5 1.0 6 0.75 3 0.75 LOAD COMB 210 1.0DL+0.75LL+0.75(0.75EQ-Z)5 1.0 6 0.75 4 0.75 LOAD COMB 211 0.6DL+0.7EQX5 0.6 1 0.7 LOAD COMB 212 0.6DL+0.7EQ-X5 0.6 2 0.7 LOAD COMB 213 0.6DL+0.7EQZ5 0.6 3 0.7 LOAD COMB 214 0.6DL+0.7EQ-Z5 0.6 4 0.7 **PERFORM ANALYSIS*DEFINE ENVELOPE201 TO 214 ENVELOPE 301 TYPE SERVICEABILITYEND DEFINE ENVELOPE*****************************************PARAMETER 1CODE AISC UNIFIED 2010TRACK 2 ALLFYLD 2.53104e+007 ALLBEAM 1 ALLDJ1 4 MEMB 2DJ2 2 MEMB 2DFF 240 ALLCHECK CODE ALLFINISH
You need to add LOAD LIST ENV 301 command before PARAMETER 1. Please refer to the attached model.7674.a1.std
