Differences between the Area, Floor, Plate and Surface loads, and if possible, an example of the application regarding to each of the load type.
Hi, my understanding to the Surface load is that, correct me if i am wrong,  the load will not be transferred to the structural member whereas the floor load is the load you can applied to the structure due to floor loading that isnt the part of the structure. However, I am not so sure about the Plate and Area loads. Can anyone tell the differences between the Area, Floor, Plate and Surface loads, and if possible, an example of the application regarding to each of the load type.
Thanks in advance.
Aric.
  • The surface pre load can be applied on surfaces while plate pressure load can be applied on plate elements only. Floor load or Area load are used when the entity transmitting the load, such as a slab, is not part of the structural model. The Area Load or One way Load may be used for modeling one-way distribution and the Floor Load may be used for modeling two-way distribution. For details please go through the Technical Reference Manual section 5.32.4.
Reply
