ERROR When Analyze multiple STAAD.Pro models in a batch processing
Hi all,
With refer to topic https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/29436/analyze-multiple-staad-pro-models-in-a-batch-processing
I have  created a .bat file with the following command: "C:\Program Files (x86)\SProV8i SS6\STAAD\Staadpro.exe" /s STAAD "EXAMP01.std"
Put this batch file in the same location with the EXAMP01.std file but still can not run. The error as captured below. Please kindly advice what's wrong with my file.
On the other hand, for checking, I have edit the command in batch file with only: "C:\Program Files (x86)\SProV8i SS6\STAAD\Staadpro.exe". when I run the batch file, Staad can open.
Thank you very much.
Parents Reply Children
