drive.google.com/.../view
Surface 23 seems to be defined incorrectly in the model. Go to STAAD Editor and change line
180 191 192 181 192 191 SURFACE 23
to
180 191 192 181 SURFACE 23
and this error should not be reported anymore.
Answer Verified By: Rolls Grant Vasquez
STAAD.Pro V8i is not supported anymore, The latest version is STAAD.Pro CONNECT Edition version 22.05.00.131 and we recommend in using it. Please note that surfaces have been deprecated from STAAD.Pro CONNECT Edition and walls should be modeled by using plate elements (Parametric Models tool).
