I was checking the results from the "Results Along a Line" output using the plate center stresses and the plate areas. I could match all the results except Fx. I found a document the explained the Results Along a Line and found that Fx was calculated using Fx = sum(SLX*w*t)/L. Can someone explain why "w" is used in this formula rather than the height of the plate element since SLX is a normal stress on the vertical face of the element/plate? Document is attached.
PDF
Hello Jeremy, could you guide me, how do you select only the plates from 3514 to 3521, when the plane cut selects the perpendicular plates, the same happens with the line cut, greetings
