Hello Modestas,
I am trying to design connection as per EC-3 and using European sections but RAM is showing error as below:
Also tell me is it possible to design Column-Column bolted end plate flushed from all sides in STAAD.
Where can I see the explanation of all joints options available in RAM prior to Design.
I am using integrated RAM model with STAAD V8i 20.07.11.90.
I think this is the latest V8i version apart from connect edition.
Do reply as early as possible.
Vishal
Aren't both European and German HE sections are same?
So just change in library makes difference, why?
RAM Connection does not recognize German library. Please use European instead.
