Hi everyone,
I have a couple of questions that need to be addressed here:
1/ Where is the section in the AS 3600 that dictates which one is blade column and which one is wall?
2/ I asked the question 1/ because in Ram Concept, if we define a vertical element as column, the program would allow us to do punching check design but it is not the case for wall definition. Could you guys explain why is there something like that? How could we know there would be no punching shear faillure around wall area?
3/ What is the effect of "shear wall" if we tick on that in wall definition?
4/ Some people put the bending stiffness factor for column around 0-0.5, mostly 0.25. Any hints for me about that?
Thanks all you guys in advance.
Thank Seth for your explanation. It was really enlightening. I am trying to do an excel spreadsheet to manually check punching shear for wall or column with whatever dimensions. What confuses me is finding the value for σcp (average intensity of effective prestress in concrete, MPa) to apply into the formula here of AS3600-2009 section 9.2.3. Could you show me step by step to find this value in Ramconcept? Thank Seth once again.
