Problem in Installing Staad.Pro (specifically Connection Client)
Hi!
For some reason I had to refresh my Windows 10 notebook. After that I am unable to install Staad.Pro again. It is showing error 2147023293 while trying to install CONNECTION Client 10.00.06.034 (64 bit).
I tried installing CONNECTION Client using the standalone installer for it but it showed error '0x80070643'. I am attaching the log file for your reference.
CONNECTION_Client_20180315215447.log
[0CBC:0B78][2018-03-15T21:54:44]i001: Burn v3.10.3.3007, Windows v10.0 (Build 16299: Service Pack 0), path: C:\Users\Prantik\AppData\Local\Temp\{ED46CE4F-DCD9-41E6-B5EE-8ED99D6BBF82}\.cr\blg6410001019en.exe
[0CBC:0B78][2018-03-15T21:54:44]i000: Initializing numeric variable 'IsDesktopShortcutAvailable' to value '1'
[0CBC:0B78][2018-03-15T21:54:44]i000: Initializing string variable 'BeBundleProductName' to value 'CONNECTION Client'
[0CBC:0B78][2018-03-15T21:54:44]i000: Initializing numeric variable 'BeARPDisableModify' to value '1'
[0CBC:0B78][2018-03-15T21:54:44]i000: Initializing string variable 'PostInstallLaunchApplication' to value '[InstallDirectory]\Bentley.Connect.Client.exe'
[0CBC:0B78][2018-03-15T21:54:44]i000: Initializing string variable 'BeWarningOnUninstall' to value 'Removing CONNECTION Client may result in CONNECT Edition product capabilities from working correctly. If the CONNECTION Client is running, it will be shut down.'
[0CBC:0B78][2018-03-15T21:54:44]i000: Initializing numeric variable 'BeCheckUpdateIsEnabled' to value '1'
[0CBC:0B78][2018-03-15T21:54:44]i000: Initializing string variable 'InstallDirectory' to value '[CommonFiles64Folder]Bentley Shared\[BeBundleProductName]\'
[0CBC:0B78][2018-03-15T21:54:44]i000: Initializing string variable 'LayoutSavePropertyList' to value 'InstallDirectory;InstallDesktopShortcut'
[0CBC:0B78][2018-03-15T21:54:44]i000: Initializing string variable 'AddedPackageAvailablePropertyList' to value 'InstallDirectory'
[0CBC:0B78][2018-03-15T21:54:44]i000: Initializing string variable 'BentleyClientPackage_DiskSpaceCheckPath' to value '[InstallDirectory]'
[0CBC:0B78][2018-03-15T21:54:44]i000: Initializing string variable 'BeMultiLanguages' to value 'en,cs,de,es,fi,fr,it,ja,ko,nl,pl,pt-br,ru,tr,zh-cn,zh-tw'
[0CBC:0B78][2018-03-15T21:54:44]i000: Initializing string variable 'BeMultilingualRegistryKey' to value 'SOFTWARE\Bentley\Installed_Products\{FA95DCB2-7F5F-4B5C-AD0B-5E8B7E87A557}\Languages'
[0CBC:0B78][2018-03-15T21:54:44]i000: Initializing string variable 'BeSelectedLanguage' to value ''
[0CBC:0B78][2018-03-15T21:54:44]i000: Initializing string variable 'BeBundleCulture' to value ''
[0CBC:0B78][2018-03-15T21:54:44]i000: Initializing string variable 'StandardPropertyList' to value 'AdminToolsFolder;AppDataFolder;CommonAppDataFolder;CommonFilesFolder;CommonFiles64Folder;CommonFiles6432Folder;ComputerName;Date;DesktopFolder;FavoritesFolder;FontsFolder;LocalAppDataFolder;LogonUser;MyPicturesFolder;PersonalFolder;ProgramFilesFolder;ProgramFiles64Folder;ProgramFiles6432Folder;ProgramMenuFolder;StartMenuFolder;StartupFolder;SystemFolder;TempFolder;TemplateFolder;WindowsFolder;WindowsVolume;'
[0CBC:0B78][2018-03-15T21:54:44]i000: Initializing string variable 'LayoutDirectory' to value '[WindowsVolume]BentleyDownloads\[WixBundleName]\'
[0CBC:0B78][2018-03-15T21:54:44]i000: Initializing string variable 'ProductsInstalledByBundle' to value 'NoProductList'
[0CBC:0B78][2018-03-15T21:54:44]i000: Initializing string variable 'BeBuildType' to value 'Release'
[0CBC:0B78][2018-03-15T21:54:44]i000: Initializing string variable 'BeNotBuildType' to value 'Beta'
[0CBC:0B78][2018-03-15T21:54:44]i000: Initializing string variable 'BeBundleShortName' to value 'CONNECTIONClient'
[0CBC:0B78][2018-03-15T21:54:44]i000: Initializing string variable 'BeWin64Bundle' to value 'yes'
[0CBC:0B78][2018-03-15T21:54:44]i000: Initializing string variable 'BeIFUseInternalResolver' to value '0'
[0CBC:0B78][2018-03-15T21:54:44]i000: Initializing string variable 'BeEulaFileName' to value 'Eula.htm'
[0CBC:0B78][2018-03-15T21:54:44]i009: Command Line: '-burn.clean.room=C:\Users\Prantik\Desktop\blg6410001019en.exe -burn.filehandle.attached=600 -burn.filehandle.self=596'
[0CBC:0B78][2018-03-15T21:54:44]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\Prantik\Desktop\blg6410001019en.exe'
[0CBC:0B78][2018-03-15T21:54:44]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Users\Prantik\Desktop\'
[0CBC:0B78][2018-03-15T21:54:47]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\Prantik\AppData\Local\Temp\CONNECTION_Client_20180315215447.log'
[0CBC:0B78][2018-03-15T21:54:47]i052: Condition 'VersionNT >= v6.1' evaluates to true.
[0CBC:0B78][2018-03-15T21:54:47]i000: Setting string variable 'WixBundleName' to value 'CONNECTION Client'
[0CBC:0B78][2018-03-15T21:54:47]i000: Setting string variable 'WixBundleManufacturer' to value 'Bentley Systems, Incorporated'
[0CBC:0B78][2018-03-15T21:54:50]i000: Loading managed bootstrapper application.
[0CBC:0B78][2018-03-15T21:54:54]i000: Creating BA thread to run asynchronously.
[0CBC:1C5C][2018-03-15T21:54:57]i000: GetInstalledLanguage (): No value is found for HKLM registry key SOFTWARE\Bentley\Installed_Products\{FA95DCB2-7F5F-4B5C-AD0B-5E8B7E87A557}\Languages\BundleCulture
[0CBC:1C5C][2018-03-15T21:54:57]i000: GetUserDefaultUILanguage (): Language Id 1033
[0CBC:1C5C][2018-03-15T21:54:57]i000: Setting string variable 'BeBundleCulture' to value 'en'
[0CBC:1C5C][2018-03-15T21:54:57]i000: Setting TwoLetterISOLanguageName user default langauge = en, as, this is a multi-lingual package
[0CBC:1C5C][2018-03-15T21:54:57]i000: Setting Culture Info to en
[0CBC:1C5C][2018-03-15T21:54:57]i000: Setting string variable 'BeSelectedLanguage' to value 'en'
[0CBC:1C5C][2018-03-15T21:54:57]i000: Setting string variable 'BeIFMainProcesCommandLineArgs' to value ''
[0CBC:1C5C][2018-03-15T21:54:58]i000: BentleyBundle Version 11.03.00.58
[0CBC:1C5C][2018-03-15T21:54:58]i000: Setting string variable 'WixExtractedTempFolder' to value 'C:\Users\Prantik\AppData\Local\Temp\{8C78D309-717B-4012-B417-89C47F75E299}\.ba'
[0CBC:1C5C][2018-03-15T21:54:58]i000: Setting string variable 'BundleCurrentPath' to value 'C:\Users\Prantik\AppData\Local\Temp\{ED46CE4F-DCD9-41E6-B5EE-8ED99D6BBF82}\.cr'
[0CBC:1C5C][2018-03-15T21:54:58]i000: Setting string variable 'WixBundleLayoutDirectory' to value 'C:\Users\Prantik\Desktop\'
[0CBC:1C5C][2018-03-15T21:54:58]e000: Using Layout File : C:\Users\Prantik\AppData\Local\Temp\{8C78D309-717B-4012-B417-89C47F75E299}\.ba\Setup.lyt
[0CBC:1C5C][2018-03-15T21:55:01]i000: Setting BentleyClientPackage InstallLevel to 1
[0CBC:1C5C][2018-03-15T21:55:01]i000: Setting string variable 'BentleyClientPackage.AddLocal' to value 'DefaultFeature'
[0CBC:1C5C][2018-03-15T21:55:01]i000: Setting DotNet461Full InstallLevel to 1
[0CBC:1C5C][2018-03-15T21:55:01]e000: LoadTestAutomationApp(): Failed to load test dll with error Object reference not set to an instance of an object.
[0CBC:1C5C][2018-03-15T21:55:01]i000: BeDesktopClientInstallerExtension - BENTLEY BOOTSTRAPPER REGISTER
[0CBC:1C5C][2018-03-15T21:55:01]i000: BeDesktopClientInstallerExtension - Setting BeBundleUIlevel=4 (Full)
[0CBC:1C5C][2018-03-15T21:55:01]i000: Setting string variable 'BeBundleUIlevel' to value '4'
[0CBC:1C5C][2018-03-15T21:55:01]i000: Setting string variable 'BeInstallTime' to value '636567477014497390'
[0CBC:1C5C][2018-03-15T21:55:01]i000: Display is set to Full
[0CBC:1C5C][2018-03-15T21:55:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/BasicInstallDirectorySelectionUserControl.xaml
[0CBC:1C5C][2018-03-15T21:55:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/UninstallVerificationUserConstrol.xaml
[0CBC:1C5C][2018-03-15T21:55:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/DeploymentImageSettingsControl.xaml
[0CBC:1C5C][2018-03-15T21:55:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/FeatureConfigUserControl.xaml
[0CBC:1C5C][2018-03-15T21:55:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ProxySettingsUserControl.xaml
[0CBC:1C5C][2018-03-15T21:55:04]i000: Register callbak=ProxySettingsPage
[0CBC:1C5C][2018-03-15T21:55:04]i000: Display Page=ProxySettingsPage
[0CBC:1C5C][2018-03-15T21:55:04]i000: Cannot Display Page=ProxySettingsPage
[0CBC:1C5C][2018-03-15T21:55:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ErrorUserControl.xaml
[0CBC:1C5C][2018-03-15T21:55:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/MaintenanceUserControl.xaml
[0CBC:1C5C][2018-03-15T21:55:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/RepairSelectionUserControl.xaml
[0CBC:1C5C][2018-03-15T21:55:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/AddedPackageUserControl.xaml
[0CBC:1C5C][2018-03-15T21:55:05]e000: Loading component /SetupPagesLib;v1.0.0.0;component/RunningProcessesUserControl.xaml
[0CBC:0B78][2018-03-15T21:55:06]i100: Detect begin, 2 packages
[0CBC:0B78][2018-03-15T21:55:06]i000: DetectBegin: e.Install=false, PlannedAction=Unknown, Setting InstallState=DetectedAbsent
[0CBC:0B78][2018-03-15T21:55:06]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay
[0CBC:0B78][2018-03-15T21:55:06]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck
[0CBC:0B78][2018-03-15T21:55:06]i000: DetectBegin: Installed State of Package DetectedAbsent
[0CBC:0B78][2018-03-15T21:55:06]i000: Setting string variable 'NetFramework46Version' to value '461308'
[0CBC:0B78][2018-03-15T21:55:06]i052: Condition '(NetFramework46Version >= 394271 AND VersionNT < v10.0.0.0) OR (NetFramework46Version >= 394254 AND VersionNT >= v10.0.0.0) OR (BeEmbeddedDisplay)' evaluates to true.
[0CBC:0B78][2018-03-15T21:55:06]i101: Detected package: BentleyClientPackage, state: Absent, cached: None
[0CBC:0B78][2018-03-15T21:55:06]i104: Detected package: BentleyClientPackage, feature: DefaultFeature, state: Absent
[0CBC:0B78][2018-03-15T21:55:06]i101: Detected package: DotNet461Full, state: Present, cached: None
[0CBC:0B78][2018-03-15T21:55:06]i000: Detect complete Start
[0CBC:0B78][2018-03-15T21:55:06]i000: Setting string variable 'BePlannedAction' to value 'Install'
[0CBC:0B78][2018-03-15T21:55:06]i000: BentleyClientPackage AnalyzeFeatureConditions: LaunchAction=Install
[0CBC:0B78][2018-03-15T21:55:06]i000: BentleyClientPackage AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[0CBC:0B78][2018-03-15T21:55:06]i000: BentleyClientPackage AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[0CBC:0B78][2018-03-15T21:55:06]i000: DotNet461Full AnalyzeFeatureConditions: LaunchAction=Install
[0CBC:0B78][2018-03-15T21:55:06]i000: DotNet461Full AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[0CBC:0B78][2018-03-15T21:55:06]i000: DotNet461Full AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[0CBC:0B78][2018-03-15T21:55:06]i000: Detection complete planned action: Install
[0CBC:0B78][2018-03-15T21:55:06]i000: DetectComplete (): Since action is =Install, performing CheckForAddOnRelatedBundle
[0CBC:0B78][2018-03-15T21:55:06]i000: CheckForAddOnRelatedBundle (): CURRENT Bundle Tag properties IsAddOn=False, IsLangPack=False, IsPatch=False, IsWin64=True, Classification=, ServicePack=0
[0CBC:0B78][2018-03-15T21:55:06]e000: CheckForAddOnRelatedBundle (): This product is not a Patch, LangPack or AddOn. Hence, not searching for related bundles
[0CBC:0B78][2018-03-15T21:55:06]i052: Condition 'Privileged OR BePlannedAction~="Layout" OR SkipPrivilegeCheck' evaluates to true.
[0CBC:0B78][2018-03-15T21:55:06]i052: Condition 'VersionNT64' evaluates to true.
[0CBC:0B78][2018-03-15T21:55:06]i000: SessionMutex: Creating new SessionMutex
[0CBC:0B78][2018-03-15T21:55:06]i000: SessionMutex: Creating Mutex with Name={440acd85-4ab2-4633-8863-745e71ac3ad0}-InstallMutex
[0CBC:0B78][2018-03-15T21:55:06]i000: SessionMutex: Created new SessionMutex with IsMutexOwned=True
[0CBC:0B78][2018-03-15T21:55:06]i000: Setting string variable 'BeBundleVersion' to value '[WixBundleVersion]'
[0CBC:0B78][2018-03-15T21:55:06]i000: WixInstallBA::SilentPlan
[0CBC:0B78][2018-03-15T21:55:06]i000: Checking ADDLOCAL and REMOVE...
[0CBC:0B78][2018-03-15T21:55:06]i199: Detect complete, result: 0x0
[0CBC:1C5C][2018-03-15T21:55:11]i052: Condition 'NOT BePlannedAction="Uninstall" AND NOT BePlannedAction="Repair"' evaluates to true.
[0CBC:1C5C][2018-03-15T21:55:12]i000: WixInstallBA::Plan
[0CBC:1C5C][2018-03-15T21:55:12]i000: WixInstallBA::SetupModel Plan
[0CBC:1C5C][2018-03-15T21:55:12]i000: SetupModel::Before Plan
[0CBC:1754][2018-03-15T21:55:12]i000: Before Plan Async
[0CBC:1754][2018-03-15T21:55:12]i000: SetupViewModel::Before Plan
[0CBC:1754][2018-03-15T21:55:12]i000: Is Compressed in Container yes
[0CBC:1754][2018-03-15T21:55:12]i000: FeatureNodeMachineState.Present True
[0CBC:1754][2018-03-15T21:55:12]i000: WixInstallBA::Before Plan Complete
[0CBC:1754][2018-03-15T21:55:12]i000: WixInstallBA::Engine Plan
[0CBC:0B78][2018-03-15T21:55:12]i200: Plan begin, 2 packages, action: Install
[0CBC:0B78][2018-03-15T21:55:12]i204: Plan 1 msi features for package: BentleyClientPackage
[0CBC:0B78][2018-03-15T21:55:12]i000: Setting string variable 'BentleyClientPackage_DefaultFeature_IsInstalling' to value '1'
[0CBC:0B78][2018-03-15T21:55:12]i203: Planned feature: DefaultFeature, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove
[0CBC:0B78][2018-03-15T21:55:12]i000: Setting string variable 'WixBundleRollbackLog_BentleyClientPackage' to value 'C:\Users\Prantik\AppData\Local\Temp\CONNECTION_Client_20180315215447_000_BentleyClientPackage_rollback.log'
[0CBC:0B78][2018-03-15T21:55:12]i000: Setting string variable 'WixBundleLog_BentleyClientPackage' to value 'C:\Users\Prantik\AppData\Local\Temp\CONNECTION_Client_20180315215447_000_BentleyClientPackage.log'
[0CBC:0B78][2018-03-15T21:55:12]w321: Skipping dependency registration on package with no dependency providers: DotNet461Full
[0CBC:0B78][2018-03-15T21:55:12]i201: Planned package: BentleyClientPackage, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[0CBC:0B78][2018-03-15T21:55:12]i201: Planned package: DotNet461Full, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[0CBC:0B78][2018-03-15T21:55:12]i000: GetWindowsRootDriveName (): winRoot=C:\
[0CBC:0B78][2018-03-15T21:55:12]i000: IsPathRooted (C:\): true
[0CBC:0B78][2018-03-15T21:55:12]i000: GetWindowsRootDriveName (): DriveInfo.Name=C:\
[0CBC:0B78][2018-03-15T21:55:12]i000: getUsedDriveNamesForInstall (): windowsRootDrive=C:\
[0CBC:0B78][2018-03-15T21:55:12]i000: getUsedDriveNamesForInstall (): windowsRootDrive=C:\, FileInfo.Length=44006544, FileName=C:\Users\Prantik\Desktop\blg6410001019en.exe
[0CBC:0B78][2018-03-15T21:55:12]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=44006544
[0CBC:0B78][2018-03-15T21:55:12]i000: GetDriveName (C:\): DriveInfo.Name=C:\
[0CBC:0B78][2018-03-15T21:55:12]i000: getUsedDriveNamesForInstall (): DriveName=C:\, Path=C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\
[0CBC:0B78][2018-03-15T21:55:12]i000: Warning : Install root drive C:\ is same as windows root drive C:\. Only C:\ will be check for available disk space.
[0CBC:0B78][2018-03-15T21:55:12]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=133676513, NewSize=177683057
[0CBC:0B78][2018-03-15T21:55:12]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft .NET Framework 4.6.1. Next
[0CBC:0B78][2018-03-15T21:55:12]i000: checkInstallSize (): Checking for drive C:\
[0CBC:0B78][2018-03-15T21:55:12]i000: checkInstallSize (): Requested Drive-List contains drive C:\
[0CBC:0B78][2018-03-15T21:55:12]i000: checkInstallSize (): Checking for drive D:\
[0CBC:0B78][2018-03-15T21:55:12]i000: checkInstallSize (): Checking for drive E:\
[0CBC:0B78][2018-03-15T21:55:12]i000: checkInstallSize (): Checking for drive F:\
[0CBC:0B78][2018-03-15T21:55:12]i000: checkInstallSize (): Checking for drive G:\
[0CBC:0B78][2018-03-15T21:55:12]i000: checkInstallSize (): Checking for drive H:\
[0CBC:0B78][2018-03-15T21:55:12]i000: validateInstallSize (): Result=True
[0CBC:0B78][2018-03-15T21:55:12]i000: PlanComplete: Called
[0CBC:0B78][2018-03-15T21:55:12]i000: Setting string variable 'BentleyClientPackage_RequestedState' to value '1'
[0CBC:0B78][2018-03-15T21:55:12]i000: Setting string variable 'DotNet461Full_RequestedState' to value '1'
[0CBC:0B78][2018-03-15T21:55:12]i000: WixInstallBA::Apply
[0CBC:0B78][2018-03-15T21:55:12]i000: WixInstallBA::Engine Apply
[0CBC:0B78][2018-03-15T21:55:12]i299: Plan complete, result: 0x0
[0CBC:0B78][2018-03-15T21:55:12]i300: Apply begin
[0CBC:0B78][2018-03-15T21:55:12]i000: DisplayMessage (Installing CONNECTION Client)
[0CBC:0B78][2018-03-15T21:55:12]i000: BeDesktopClientInstallerExtension - Attempting to Close CC in Application_ApplyBegin
[0CBC:0B78][2018-03-15T21:55:12]i000: BeDesktopClientInstallerExtension - Starting CloseCC Action
[0CBC:0B78][2018-03-15T21:55:12]i000: BeDesktopClientInstallerExtension - Finished CloseCC Action
[0CBC:0B78][2018-03-15T21:55:12]i000: BeDesktopClientInstallerExtension - Attempting to Kill CC in Application_ApplyBegin
[0CBC:0B78][2018-03-15T21:55:12]i000: BeDesktopClientInstallerExtension - Starting KillCC Action
[0CBC:0B78][2018-03-15T21:55:12]i000: BeDesktopClientInstallerExtension - Finished KillCC Action
[0CBC:0B78][2018-03-15T21:55:13]i010: Launching elevated engine process.
[0CBC:0B78][2018-03-15T21:55:18]i011: Launched elevated engine process.
[0CBC:0B78][2018-03-15T21:55:18]i012: Connected to elevated engine.
[216C:22F0][2018-03-15T21:55:18]i358: Pausing automatic updates.
[216C:22F0][2018-03-15T21:55:19]i359: Paused automatic updates.
[216C:22F0][2018-03-15T21:55:19]i360: Creating a system restore point.
[216C:22F0][2018-03-15T21:56:25]i361: Created a system restore point.
[216C:22F0][2018-03-15T21:56:25]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{440acd85-4ab2-4633-8863-745e71ac3ad0}, options: 0x7, disable resume: No
[216C:22F0][2018-03-15T21:56:25]i000: Caching bundle from: 'C:\Users\Prantik\AppData\Local\Temp\{8C78D309-717B-4012-B417-89C47F75E299}\.be\Setup_CONNECTIONClientx64_10.00.10.019.exe' to: 'C:\ProgramData\Package Cache\{440acd85-4ab2-4633-8863-745e71ac3ad0}\Setup_CONNECTIONClientx64_10.00.10.019.exe'
[216C:22F0][2018-03-15T21:56:25]i320: Registering bundle dependency provider: {440acd85-4ab2-4633-8863-745e71ac3ad0}, version: 10.0.10.19
[216C:22F0][2018-03-15T21:56:25]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{440acd85-4ab2-4633-8863-745e71ac3ad0}, resume: Active, restart initiated: No, disable resume: No
[0CBC:0B78][2018-03-15T21:56:25]i000: Installation chain initiated package from
[216C:2324][2018-03-15T21:56:30]i305: Verified acquired payload: BentleyClientPackage at path: C:\ProgramData\Package Cache\.unverified\BentleyClientPackage, moving to: C:\ProgramData\Package Cache\{E5473513-7FDA-3730-9A35-71AB8F7F918E}v10.00.10.019\CONNECTIONClientx64.msi.
[216C:22F0][2018-03-15T21:56:31]i323: Registering package dependency provider: {E5473513-7FDA-3730-9A35-71AB8F7F918E}, version: 10.00.10.019, package: BentleyClientPackage
[0CBC:0B78][2018-03-15T21:56:31]i000: Installing BentleyClientPackage
[0CBC:0B78][2018-03-15T21:56:31]i000: Setting string variable 'ProductsInstalledByBundle' to value 'NoProductList;bentleyclientpackage'
[216C:22F0][2018-03-15T21:56:31]i301: Applying execute package: BentleyClientPackage, action: Install, path: C:\ProgramData\Package Cache\{E5473513-7FDA-3730-9A35-71AB8F7F918E}v10.00.10.019\CONNECTIONClientx64.msi, arguments: ' ALLUSERS="1" ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7" FROMLAUNCHSETUP="1" INSTALLDIR="C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\" CCINSTALL_DESKTOPSHORTCUTCHOICE="" PARENTINSTALL_DESKTOPSHORTCUTCHOICE="" LAUNCHINSTALLEDAPP="" BE_BUNDLE_NAME="CONNECTION Client" BE_BUNDLE_VERSION="10.0.10.19" BE_BUNDLE_UILEVEL="4" UC_CHECK_UPDATE_OPTION="" UC_CHECK_UPDATE_IS_ENABLED="1" UC_INSTALL_TIME="636567477014497390" DEFAULT_LANGUAGE="en" BUNDLE_UI_CULTURE="en" ADDLOCAL="DefaultFeature"'
[216C:22F0][2018-03-15T21:57:46]e000: Error 0x80070643: Failed to install MSI package.
[216C:22F0][2018-03-15T21:57:46]e000: Error 0x80070643: Failed to execute MSI package.
[0CBC:0B78][2018-03-15T21:57:46]e000: Error 0x80070643: Failed to configure per-machine MSI package.
[0CBC:0B78][2018-03-15T21:57:46]i000: Installed package BentleyClientPackage
[0CBC:0B78][2018-03-15T21:57:46]i000: DisplayMessage (Failed to install CONNECTION Client with error code 0x80070643. Fatal error during installation)
[0CBC:0B78][2018-03-15T21:57:46]i319: Applied execute package: BentleyClientPackage, result: 0x80070643, restart: None
[0CBC:0B78][2018-03-15T21:57:46]e000: Error 0x80070643: Failed to execute MSI package.
[0CBC:0B78][2018-03-15T21:57:46]i000: Installing BentleyClientPackage
[216C:22F0][2018-03-15T21:57:46]i318: Skipped rollback of package: BentleyClientPackage, action: Uninstall, already: Absent
[0CBC:0B78][2018-03-15T21:57:46]i319: Applied rollback package: BentleyClientPackage, result: 0x0, restart: None
[216C:22F0][2018-03-15T21:57:46]i329: Removed package dependency provider: {E5473513-7FDA-3730-9A35-71AB8F7F918E}, package: BentleyClientPackage
[216C:22F0][2018-03-15T21:57:46]i351: Removing cached package: BentleyClientPackage, from path: C:\ProgramData\Package Cache\{E5473513-7FDA-3730-9A35-71AB8F7F918E}v10.00.10.019\
[0CBC:0B78][2018-03-15T21:57:46]i000: Installation chain finished package from
[216C:22F0][2018-03-15T21:57:46]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{440acd85-4ab2-4633-8863-745e71ac3ad0}, resume: None, restart: None, disable resume: No
[216C:22F0][2018-03-15T21:57:46]i330: Removed bundle dependency provider: {440acd85-4ab2-4633-8863-745e71ac3ad0}
[216C:22F0][2018-03-15T21:57:46]i352: Removing cached bundle: {440acd85-4ab2-4633-8863-745e71ac3ad0}, from path: C:\ProgramData\Package Cache\{440acd85-4ab2-4633-8863-745e71ac3ad0}\
[216C:22F0][2018-03-15T21:57:46]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{440acd85-4ab2-4633-8863-745e71ac3ad0}, resume: None, restart initiated: No, disable resume: No
[0CBC:0B78][2018-03-15T21:57:46]i000: No application is set for launch after installation
[0CBC:0B78][2018-03-15T21:57:46]i000: Setting string variable 'ZipPathForAllLogFiles' to value 'C:\Users\Prantik\AppData\Local\Temp\CONNECTION_Client_20180315215447.zip'
[0CBC:0B78][2018-03-15T21:57:46]i000: BeDesktopClientInstallerExtension - BENTLEY BOOTSTRAPPER COMPLETE
[0CBC:0B78][2018-03-15T21:57:46]i399: Apply complete, result: 0x80070643, restart: None, ba requested restart:  No
I really need to reinstall it urgently. Hoping for some answers. Thanks.
  • Did you try downloading & installing the latest version of the Connection Client ( 10.00.10.19) ? If not, I would suggest doing that and then proceed with the installation of STAAD.Pro v8i.
  • Tried installing version 10.00.10.19 using the standalone installer and got the same error.
    The log file is attached below:
    CONNECTION_Client_20180316070333.log
    [0580:062C][2018-03-16T07:03:31]i001: Burn v3.10.3.3007, Windows v10.0 (Build 16299: Service Pack 0), path: C:\Users\Prantik\AppData\Local\Temp\{CB4FE0C5-5989-4BC9-941E-A9EBE498AC1C}\.cr\blg6410001019en.exe
    [0580:062C][2018-03-16T07:03:31]i000: Initializing numeric variable 'IsDesktopShortcutAvailable' to value '1'
    [0580:062C][2018-03-16T07:03:31]i000: Initializing string variable 'BeBundleProductName' to value 'CONNECTION Client'
    [0580:062C][2018-03-16T07:03:31]i000: Initializing numeric variable 'BeARPDisableModify' to value '1'
    [0580:062C][2018-03-16T07:03:31]i000: Initializing string variable 'PostInstallLaunchApplication' to value '[InstallDirectory]\Bentley.Connect.Client.exe'
    [0580:062C][2018-03-16T07:03:31]i000: Initializing string variable 'BeWarningOnUninstall' to value 'Removing CONNECTION Client may result in CONNECT Edition product capabilities from working correctly. If the CONNECTION Client is running, it will be shut down.'
    [0580:062C][2018-03-16T07:03:31]i000: Initializing numeric variable 'BeCheckUpdateIsEnabled' to value '1'
    [0580:062C][2018-03-16T07:03:31]i000: Initializing string variable 'InstallDirectory' to value '[CommonFiles64Folder]Bentley Shared\[BeBundleProductName]\'
    [0580:062C][2018-03-16T07:03:31]i000: Initializing string variable 'LayoutSavePropertyList' to value 'InstallDirectory;InstallDesktopShortcut'
    [0580:062C][2018-03-16T07:03:31]i000: Initializing string variable 'AddedPackageAvailablePropertyList' to value 'InstallDirectory'
    [0580:062C][2018-03-16T07:03:31]i000: Initializing string variable 'BentleyClientPackage_DiskSpaceCheckPath' to value '[InstallDirectory]'
    [0580:062C][2018-03-16T07:03:31]i000: Initializing string variable 'BeMultiLanguages' to value 'en,cs,de,es,fi,fr,it,ja,ko,nl,pl,pt-br,ru,tr,zh-cn,zh-tw'
    [0580:062C][2018-03-16T07:03:31]i000: Initializing string variable 'BeMultilingualRegistryKey' to value 'SOFTWARE\Bentley\Installed_Products\{FA95DCB2-7F5F-4B5C-AD0B-5E8B7E87A557}\Languages'
    [0580:062C][2018-03-16T07:03:31]i000: Initializing string variable 'BeSelectedLanguage' to value ''
    [0580:062C][2018-03-16T07:03:31]i000: Initializing string variable 'BeBundleCulture' to value ''
    [0580:062C][2018-03-16T07:03:31]i000: Initializing string variable 'StandardPropertyList' to value 'AdminToolsFolder;AppDataFolder;CommonAppDataFolder;CommonFilesFolder;CommonFiles64Folder;CommonFiles6432Folder;ComputerName;Date;DesktopFolder;FavoritesFolder;FontsFolder;LocalAppDataFolder;LogonUser;MyPicturesFolder;PersonalFolder;ProgramFilesFolder;ProgramFiles64Folder;ProgramFiles6432Folder;ProgramMenuFolder;StartMenuFolder;StartupFolder;SystemFolder;TempFolder;TemplateFolder;WindowsFolder;WindowsVolume;'
    [0580:062C][2018-03-16T07:03:31]i000: Initializing string variable 'LayoutDirectory' to value '[WindowsVolume]BentleyDownloads\[WixBundleName]\'
    [0580:062C][2018-03-16T07:03:31]i000: Initializing string variable 'ProductsInstalledByBundle' to value 'NoProductList'
    [0580:062C][2018-03-16T07:03:31]i000: Initializing string variable 'BeBuildType' to value 'Release'
    [0580:062C][2018-03-16T07:03:31]i000: Initializing string variable 'BeNotBuildType' to value 'Beta'
    [0580:062C][2018-03-16T07:03:31]i000: Initializing string variable 'BeBundleShortName' to value 'CONNECTIONClient'
    [0580:062C][2018-03-16T07:03:31]i000: Initializing string variable 'BeWin64Bundle' to value 'yes'
    [0580:062C][2018-03-16T07:03:31]i000: Initializing string variable 'BeIFUseInternalResolver' to value '0'
    [0580:062C][2018-03-16T07:03:31]i000: Initializing string variable 'BeEulaFileName' to value 'Eula.htm'
    [0580:062C][2018-03-16T07:03:31]i009: Command Line: '-burn.clean.room=C:\Users\Prantik\Desktop\blg6410001019en.exe -burn.filehandle.attached=504 -burn.filehandle.self=508'
    [0580:062C][2018-03-16T07:03:31]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\Prantik\Desktop\blg6410001019en.exe'
    [0580:062C][2018-03-16T07:03:31]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Users\Prantik\Desktop\'
    [0580:062C][2018-03-16T07:03:33]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\Prantik\AppData\Local\Temp\CONNECTION_Client_20180316070333.log'
    [0580:062C][2018-03-16T07:03:33]i052: Condition 'VersionNT >= v6.1' evaluates to true.
    [0580:062C][2018-03-16T07:03:33]i000: Setting string variable 'WixBundleName' to value 'CONNECTION Client'
    [0580:062C][2018-03-16T07:03:33]i000: Setting string variable 'WixBundleManufacturer' to value 'Bentley Systems, Incorporated'
    [0580:062C][2018-03-16T07:03:35]i000: Loading managed bootstrapper application.
    [0580:062C][2018-03-16T07:03:37]i000: Creating BA thread to run asynchronously.
    [0580:1B90][2018-03-16T07:03:42]i000: GetInstalledLanguage (): No value is found for HKLM registry key SOFTWARE\Bentley\Installed_Products\{FA95DCB2-7F5F-4B5C-AD0B-5E8B7E87A557}\Languages\BundleCulture
    [0580:1B90][2018-03-16T07:03:42]i000: GetUserDefaultUILanguage (): Language Id 1033
    [0580:1B90][2018-03-16T07:03:42]i000: Setting string variable 'BeBundleCulture' to value 'en'
    [0580:1B90][2018-03-16T07:03:42]i000: Setting TwoLetterISOLanguageName user default langauge = en, as, this is a multi-lingual package
    [0580:1B90][2018-03-16T07:03:42]i000: Setting Culture Info to en
    [0580:1B90][2018-03-16T07:03:42]i000: Setting string variable 'BeSelectedLanguage' to value 'en'
    [0580:1B90][2018-03-16T07:03:42]i000: Setting string variable 'BeIFMainProcesCommandLineArgs' to value ''
    [0580:1B90][2018-03-16T07:03:42]i000: BentleyBundle Version 11.03.00.58
    [0580:1B90][2018-03-16T07:03:43]i000: Setting string variable 'WixExtractedTempFolder' to value 'C:\Users\Prantik\AppData\Local\Temp\{BE7BCAFC-14BD-44A2-964C-B8D1FE2EB9D4}\.ba'
    [0580:1B90][2018-03-16T07:03:43]i000: Setting string variable 'BundleCurrentPath' to value 'C:\Users\Prantik\AppData\Local\Temp\{CB4FE0C5-5989-4BC9-941E-A9EBE498AC1C}\.cr'
    [0580:1B90][2018-03-16T07:03:43]i000: Setting string variable 'WixBundleLayoutDirectory' to value 'C:\Users\Prantik\Desktop\'
    [0580:1B90][2018-03-16T07:03:43]e000: Using Layout File : C:\Users\Prantik\AppData\Local\Temp\{BE7BCAFC-14BD-44A2-964C-B8D1FE2EB9D4}\.ba\Setup.lyt
    [0580:1B90][2018-03-16T07:03:46]i000: Setting BentleyClientPackage InstallLevel to 1
    [0580:1B90][2018-03-16T07:03:46]i000: Setting string variable 'BentleyClientPackage.AddLocal' to value 'DefaultFeature'
    [0580:1B90][2018-03-16T07:03:46]i000: Setting DotNet461Full InstallLevel to 1
    [0580:1B90][2018-03-16T07:03:46]e000: LoadTestAutomationApp(): Failed to load test dll with error Object reference not set to an instance of an object.
    [0580:1B90][2018-03-16T07:03:46]i000: BeDesktopClientInstallerExtension - BENTLEY BOOTSTRAPPER REGISTER
    [0580:1B90][2018-03-16T07:03:46]i000: BeDesktopClientInstallerExtension - Setting BeBundleUIlevel=4 (Full)
    [0580:1B90][2018-03-16T07:03:46]i000: Setting string variable 'BeBundleUIlevel' to value '4'
    [0580:1B90][2018-03-16T07:03:47]i000: Setting string variable 'BeInstallTime' to value '636567806268420207'
    [0580:1B90][2018-03-16T07:03:47]i000: Display is set to Full
    [0580:1B90][2018-03-16T07:03:49]e000: Loading component /SetupPagesLib;v1.0.0.0;component/BasicInstallDirectorySelectionUserControl.xaml
    [0580:1B90][2018-03-16T07:03:49]e000: Loading component /SetupPagesLib;v1.0.0.0;component/UninstallVerificationUserConstrol.xaml
    [0580:1B90][2018-03-16T07:03:49]e000: Loading component /SetupPagesLib;v1.0.0.0;component/DeploymentImageSettingsControl.xaml
    [0580:1B90][2018-03-16T07:03:49]e000: Loading component /SetupPagesLib;v1.0.0.0;component/FeatureConfigUserControl.xaml
    [0580:1B90][2018-03-16T07:03:49]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ProxySettingsUserControl.xaml
    [0580:1B90][2018-03-16T07:03:49]i000: Register callbak=ProxySettingsPage
    [0580:1B90][2018-03-16T07:03:49]i000: Display Page=ProxySettingsPage
    [0580:1B90][2018-03-16T07:03:49]i000: Cannot Display Page=ProxySettingsPage
    [0580:1B90][2018-03-16T07:03:49]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ErrorUserControl.xaml
    [0580:1B90][2018-03-16T07:03:49]e000: Loading component /SetupPagesLib;v1.0.0.0;component/MaintenanceUserControl.xaml
    [0580:1B90][2018-03-16T07:03:49]e000: Loading component /SetupPagesLib;v1.0.0.0;component/RepairSelectionUserControl.xaml
    [0580:1B90][2018-03-16T07:03:49]e000: Loading component /SetupPagesLib;v1.0.0.0;component/AddedPackageUserControl.xaml
    [0580:1B90][2018-03-16T07:03:49]e000: Loading component /SetupPagesLib;v1.0.0.0;component/RunningProcessesUserControl.xaml
    [0580:062C][2018-03-16T07:03:51]i100: Detect begin, 2 packages
    [0580:062C][2018-03-16T07:03:51]i000: DetectBegin: e.Install=false, PlannedAction=Unknown, Setting InstallState=DetectedAbsent
    [0580:062C][2018-03-16T07:03:51]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay
    [0580:062C][2018-03-16T07:03:51]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck
    [0580:062C][2018-03-16T07:03:51]i000: DetectBegin: Installed State of Package DetectedAbsent
    [0580:062C][2018-03-16T07:03:51]i000: Setting string variable 'NetFramework46Version' to value '461308'
    [0580:062C][2018-03-16T07:03:51]i052: Condition '(NetFramework46Version >= 394271 AND VersionNT < v10.0.0.0) OR (NetFramework46Version >= 394254 AND VersionNT >= v10.0.0.0) OR (BeEmbeddedDisplay)' evaluates to true.
    [0580:062C][2018-03-16T07:03:51]i101: Detected package: BentleyClientPackage, state: Absent, cached: None
    [0580:062C][2018-03-16T07:03:51]i104: Detected package: BentleyClientPackage, feature: DefaultFeature, state: Absent
    [0580:062C][2018-03-16T07:03:51]i101: Detected package: DotNet461Full, state: Present, cached: None
    [0580:062C][2018-03-16T07:03:51]i000: Detect complete Start
    [0580:062C][2018-03-16T07:03:51]i000: Setting string variable 'BePlannedAction' to value 'Install'
    [0580:062C][2018-03-16T07:03:51]i000: BentleyClientPackage AnalyzeFeatureConditions: LaunchAction=Install
    [0580:062C][2018-03-16T07:03:51]i000: BentleyClientPackage AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
    [0580:062C][2018-03-16T07:03:51]i000: BentleyClientPackage AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
    [0580:062C][2018-03-16T07:03:51]i000: DotNet461Full AnalyzeFeatureConditions: LaunchAction=Install
    [0580:062C][2018-03-16T07:03:51]i000: DotNet461Full AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0580:062C][2018-03-16T07:03:51]i000: DotNet461Full AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
    [0580:062C][2018-03-16T07:03:51]i000: Detection complete planned action: Install
    [0580:062C][2018-03-16T07:03:51]i000: DetectComplete (): Since action is =Install, performing CheckForAddOnRelatedBundle
    [0580:062C][2018-03-16T07:03:51]i000: CheckForAddOnRelatedBundle (): CURRENT Bundle Tag properties IsAddOn=False, IsLangPack=False, IsPatch=False, IsWin64=True, Classification=, ServicePack=0
    [0580:062C][2018-03-16T07:03:51]e000: CheckForAddOnRelatedBundle (): This product is not a Patch, LangPack or AddOn. Hence, not searching for related bundles
    [0580:062C][2018-03-16T07:03:51]i052: Condition 'Privileged OR BePlannedAction~="Layout" OR SkipPrivilegeCheck' evaluates to true.
    [0580:062C][2018-03-16T07:03:51]i052: Condition 'VersionNT64' evaluates to true.
    [0580:062C][2018-03-16T07:03:51]i000: SessionMutex: Creating new SessionMutex
    [0580:062C][2018-03-16T07:03:51]i000: SessionMutex: Creating Mutex with Name={440acd85-4ab2-4633-8863-745e71ac3ad0}-InstallMutex
    [0580:062C][2018-03-16T07:03:51]i000: SessionMutex: Created new SessionMutex with IsMutexOwned=True
    [0580:062C][2018-03-16T07:03:51]i000: Setting string variable 'BeBundleVersion' to value '[WixBundleVersion]'
    [0580:062C][2018-03-16T07:03:51]i000: WixInstallBA::SilentPlan
    [0580:062C][2018-03-16T07:03:51]i000: Checking ADDLOCAL and REMOVE...
    [0580:062C][2018-03-16T07:03:51]i199: Detect complete, result: 0x0
    [0580:1B90][2018-03-16T07:04:09]i052: Condition 'NOT BePlannedAction="Uninstall" AND NOT BePlannedAction="Repair"' evaluates to true.
    [0580:1B90][2018-03-16T07:04:12]i000: WixInstallBA::Plan
    [0580:1B90][2018-03-16T07:04:12]i000: WixInstallBA::SetupModel Plan
    [0580:1B90][2018-03-16T07:04:12]i000: SetupModel::Before Plan
    [0580:29B0][2018-03-16T07:04:12]i000: Before Plan Async
    [0580:29B0][2018-03-16T07:04:12]i000: SetupViewModel::Before Plan
    [0580:29B0][2018-03-16T07:04:12]i000: Is Compressed in Container yes
    [0580:29B0][2018-03-16T07:04:12]i000: FeatureNodeMachineState.Present True
    [0580:29B0][2018-03-16T07:04:12]i000: WixInstallBA::Before Plan Complete
    [0580:29B0][2018-03-16T07:04:12]i000: WixInstallBA::Engine Plan
    [0580:062C][2018-03-16T07:04:12]i200: Plan begin, 2 packages, action: Install
    [0580:062C][2018-03-16T07:04:12]i204: Plan 1 msi features for package: BentleyClientPackage
    [0580:062C][2018-03-16T07:04:12]i000: Setting string variable 'BentleyClientPackage_DefaultFeature_IsInstalling' to value '1'
    [0580:062C][2018-03-16T07:04:12]i203: Planned feature: DefaultFeature, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove
    [0580:062C][2018-03-16T07:04:12]i000: Setting string variable 'WixBundleRollbackLog_BentleyClientPackage' to value 'C:\Users\Prantik\AppData\Local\Temp\CONNECTION_Client_20180316070333_000_BentleyClientPackage_rollback.log'
    [0580:062C][2018-03-16T07:04:12]i000: Setting string variable 'WixBundleLog_BentleyClientPackage' to value 'C:\Users\Prantik\AppData\Local\Temp\CONNECTION_Client_20180316070333_000_BentleyClientPackage.log'
    [0580:062C][2018-03-16T07:04:12]w321: Skipping dependency registration on package with no dependency providers: DotNet461Full
    [0580:062C][2018-03-16T07:04:12]i201: Planned package: BentleyClientPackage, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
    [0580:062C][2018-03-16T07:04:12]i201: Planned package: DotNet461Full, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
    [0580:062C][2018-03-16T07:04:12]i000: GetWindowsRootDriveName (): winRoot=C:\
    [0580:062C][2018-03-16T07:04:12]i000: IsPathRooted (C:\): true
    [0580:062C][2018-03-16T07:04:12]i000: GetWindowsRootDriveName (): DriveInfo.Name=C:\
    [0580:062C][2018-03-16T07:04:12]i000: getUsedDriveNamesForInstall (): windowsRootDrive=C:\
    [0580:062C][2018-03-16T07:04:12]i000: getUsedDriveNamesForInstall (): windowsRootDrive=C:\, FileInfo.Length=44006544, FileName=C:\Users\Prantik\Desktop\blg6410001019en.exe
    [0580:062C][2018-03-16T07:04:12]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=44006544
    [0580:062C][2018-03-16T07:04:12]i000: GetDriveName (C:\): DriveInfo.Name=C:\
    [0580:062C][2018-03-16T07:04:12]i000: getUsedDriveNamesForInstall (): DriveName=C:\, Path=C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\
    [0580:062C][2018-03-16T07:04:12]i000: Warning : Install root drive C:\ is same as windows root drive C:\. Only C:\ will be check for available disk space.
    [0580:062C][2018-03-16T07:04:12]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=133676513, NewSize=177683057
    [0580:062C][2018-03-16T07:04:12]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft .NET Framework 4.6.1. Next
    [0580:062C][2018-03-16T07:04:12]i000: checkInstallSize (): Checking for drive C:\
    [0580:062C][2018-03-16T07:04:12]i000: checkInstallSize (): Requested Drive-List contains drive C:\
    [0580:062C][2018-03-16T07:04:12]i000: checkInstallSize (): Checking for drive D:\
    [0580:062C][2018-03-16T07:04:12]i000: checkInstallSize (): Checking for drive E:\
    [0580:062C][2018-03-16T07:04:12]i000: checkInstallSize (): Checking for drive F:\
    [0580:062C][2018-03-16T07:04:12]i000: checkInstallSize (): Checking for drive G:\
    [0580:062C][2018-03-16T07:04:12]i000: checkInstallSize (): Checking for drive H:\
    [0580:062C][2018-03-16T07:04:12]i000: validateInstallSize (): Result=True
    [0580:062C][2018-03-16T07:04:12]i000: PlanComplete: Called
    [0580:062C][2018-03-16T07:04:12]i000: Setting string variable 'BentleyClientPackage_RequestedState' to value '1'
    [0580:062C][2018-03-16T07:04:12]i000: Setting string variable 'DotNet461Full_RequestedState' to value '1'
    [0580:062C][2018-03-16T07:04:12]i000: WixInstallBA::Apply
    [0580:062C][2018-03-16T07:04:12]i000: WixInstallBA::Engine Apply
    [0580:062C][2018-03-16T07:04:12]i299: Plan complete, result: 0x0
    [0580:062C][2018-03-16T07:04:12]i300: Apply begin
    [0580:062C][2018-03-16T07:04:12]i000: DisplayMessage (Installing CONNECTION Client)
    [0580:062C][2018-03-16T07:04:12]i000: BeDesktopClientInstallerExtension - Attempting to Close CC in Application_ApplyBegin
    [0580:062C][2018-03-16T07:04:12]i000: BeDesktopClientInstallerExtension - Starting CloseCC Action
    [0580:062C][2018-03-16T07:04:12]i000: BeDesktopClientInstallerExtension - Finished CloseCC Action
    [0580:062C][2018-03-16T07:04:12]i000: BeDesktopClientInstallerExtension - Attempting to Kill CC in Application_ApplyBegin
    [0580:062C][2018-03-16T07:04:12]i000: BeDesktopClientInstallerExtension - Starting KillCC Action
    [0580:062C][2018-03-16T07:04:12]i000: BeDesktopClientInstallerExtension - Finished KillCC Action
    [0580:062C][2018-03-16T07:04:12]i010: Launching elevated engine process.
    [0580:062C][2018-03-16T07:04:15]i011: Launched elevated engine process.
    [0580:062C][2018-03-16T07:04:16]i012: Connected to elevated engine.
    [03AC:2A2C][2018-03-16T07:04:16]i358: Pausing automatic updates.
    [03AC:2A2C][2018-03-16T07:04:16]i359: Paused automatic updates.
    [03AC:2A2C][2018-03-16T07:04:16]i360: Creating a system restore point.
    [03AC:2A2C][2018-03-16T07:05:01]i361: Created a system restore point.
    [03AC:2A2C][2018-03-16T07:05:01]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{440acd85-4ab2-4633-8863-745e71ac3ad0}, options: 0x7, disable resume: No
    [03AC:2A2C][2018-03-16T07:05:01]i000: Caching bundle from: 'C:\Users\Prantik\AppData\Local\Temp\{BE7BCAFC-14BD-44A2-964C-B8D1FE2EB9D4}\.be\Setup_CONNECTIONClientx64_10.00.10.019.exe' to: 'C:\ProgramData\Package Cache\{440acd85-4ab2-4633-8863-745e71ac3ad0}\Setup_CONNECTIONClientx64_10.00.10.019.exe'
    [03AC:2A2C][2018-03-16T07:05:01]i320: Registering bundle dependency provider: {440acd85-4ab2-4633-8863-745e71ac3ad0}, version: 10.0.10.19
    [03AC:2A2C][2018-03-16T07:05:01]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{440acd85-4ab2-4633-8863-745e71ac3ad0}, resume: Active, restart initiated: No, disable resume: No
    [0580:062C][2018-03-16T07:05:01]i000: Installation chain initiated package from
    [03AC:1A5C][2018-03-16T07:05:02]i305: Verified acquired payload: BentleyClientPackage at path: C:\ProgramData\Package Cache\.unverified\BentleyClientPackage, moving to: C:\ProgramData\Package Cache\{E5473513-7FDA-3730-9A35-71AB8F7F918E}v10.00.10.019\CONNECTIONClientx64.msi.
    [03AC:2A2C][2018-03-16T07:05:03]i323: Registering package dependency provider: {E5473513-7FDA-3730-9A35-71AB8F7F918E}, version: 10.00.10.019, package: BentleyClientPackage
    [0580:062C][2018-03-16T07:05:03]i000: Installing BentleyClientPackage
    [0580:062C][2018-03-16T07:05:03]i000: Setting string variable 'ProductsInstalledByBundle' to value 'NoProductList;bentleyclientpackage'
    [03AC:2A2C][2018-03-16T07:05:03]i301: Applying execute package: BentleyClientPackage, action: Install, path: C:\ProgramData\Package Cache\{E5473513-7FDA-3730-9A35-71AB8F7F918E}v10.00.10.019\CONNECTIONClientx64.msi, arguments: ' ALLUSERS="1" ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7" FROMLAUNCHSETUP="1" INSTALLDIR="C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\" CCINSTALL_DESKTOPSHORTCUTCHOICE="" PARENTINSTALL_DESKTOPSHORTCUTCHOICE="" LAUNCHINSTALLEDAPP="" BE_BUNDLE_NAME="CONNECTION Client" BE_BUNDLE_VERSION="10.0.10.19" BE_BUNDLE_UILEVEL="4" UC_CHECK_UPDATE_OPTION="" UC_CHECK_UPDATE_IS_ENABLED="1" UC_INSTALL_TIME="636567806268420207" DEFAULT_LANGUAGE="en" BUNDLE_UI_CULTURE="en" ADDLOCAL="DefaultFeature"'
    [03AC:2A2C][2018-03-16T07:06:47]e000: Error 0x80070643: Failed to install MSI package.
    [03AC:2A2C][2018-03-16T07:06:47]e000: Error 0x80070643: Failed to execute MSI package.
    [0580:062C][2018-03-16T07:06:47]e000: Error 0x80070643: Failed to configure per-machine MSI package.
    [0580:062C][2018-03-16T07:06:47]i000: Installed package BentleyClientPackage
    [0580:062C][2018-03-16T07:06:47]i000: DisplayMessage (Failed to install CONNECTION Client with error code 0x80070643. Fatal error during installation)
    [0580:062C][2018-03-16T07:06:47]i319: Applied execute package: BentleyClientPackage, result: 0x80070643, restart: None
    [0580:062C][2018-03-16T07:06:47]e000: Error 0x80070643: Failed to execute MSI package.
    [0580:062C][2018-03-16T07:06:47]i000: Installing BentleyClientPackage
    [03AC:2A2C][2018-03-16T07:06:47]i318: Skipped rollback of package: BentleyClientPackage, action: Uninstall, already: Absent
    [0580:062C][2018-03-16T07:06:47]i319: Applied rollback package: BentleyClientPackage, result: 0x0, restart: None
    [03AC:2A2C][2018-03-16T07:06:47]i329: Removed package dependency provider: {E5473513-7FDA-3730-9A35-71AB8F7F918E}, package: BentleyClientPackage
    [03AC:2A2C][2018-03-16T07:06:47]i351: Removing cached package: BentleyClientPackage, from path: C:\ProgramData\Package Cache\{E5473513-7FDA-3730-9A35-71AB8F7F918E}v10.00.10.019\
    [0580:062C][2018-03-16T07:06:47]i000: Installation chain finished package from
    [03AC:2A2C][2018-03-16T07:06:47]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{440acd85-4ab2-4633-8863-745e71ac3ad0}, resume: None, restart: None, disable resume: No
    [03AC:2A2C][2018-03-16T07:06:47]i330: Removed bundle dependency provider: {440acd85-4ab2-4633-8863-745e71ac3ad0}
    [03AC:2A2C][2018-03-16T07:06:47]i352: Removing cached bundle: {440acd85-4ab2-4633-8863-745e71ac3ad0}, from path: C:\ProgramData\Package Cache\{440acd85-4ab2-4633-8863-745e71ac3ad0}\
    [03AC:2A2C][2018-03-16T07:06:47]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{440acd85-4ab2-4633-8863-745e71ac3ad0}, resume: None, restart initiated: No, disable resume: No
    [0580:062C][2018-03-16T07:06:47]i000: No application is set for launch after installation
    [0580:062C][2018-03-16T07:06:47]i000: Setting string variable 'ZipPathForAllLogFiles' to value 'C:\Users\Prantik\AppData\Local\Temp\CONNECTION_Client_20180316070333.zip'
    [0580:062C][2018-03-16T07:06:48]i000: BeDesktopClientInstallerExtension - BENTLEY BOOTSTRAPPER COMPLETE
    [0580:062C][2018-03-16T07:06:48]i399: Apply complete, result: 0x80070643, restart: None, ba requested restart:  No
  • Nothing worked. I had to install Windows from scratch to install Staad.Pro.
    This was the worst possible experience. Just for installing Connection Client I had to reinstall windows completely. Bentley must review what it is trying to achieve by making such faulty programs. I am really angry and disappointed over the experience I had to go through. If I have to go through anything like this ever again I will just stop using Bentley products.
    I am not willing to waste so much time just because you decide to put some additional security measures or some bugs which prevents reinstalling of software after refreshing my PC.
    Answer Verified By: Prantik Chatterjee
