Hi All,
Every time when I place a plumbing element in Aecosim it is not displaying, rather it gives a error msg "Datagroup appears to be obsolete, please run dg update". then I have upgraded the DG but still it gives me a same error msg. Could anyone help us on this.
Parthiban.T
Which version of AECOsim are you using?
V8i Select Series 6 (08.11.09.866)
Hi Parthiban,
Which dataset are you using with AECOsim, and what is the version number of that dataset?
Hi Have this same issue with ABD SS6, any solution to this please?
regards,
ReggieCL
CH2M Singapore Pte Ltd
check the configuration of default family and part of plumbing, make sure that we are using defined one .
