respected sir,
I am solving a simple supported beam of span 2m. Material = concrete. UDL of 10kN/m throughout the span (2m), but i am getting an error after running analysis.
i am getting an error " **ERROR- IN READING MEMBER PROPERTIES. CHECK DATA FORMAT CAREFULLY."
i am getting this error again and again after adding all the date correctly. Please guide me to correct this error.
DATA:
1. STAAD SPACEINPUT FILE: F:\SProV8i SS6\STAAD\Plugins\tutorial.STD 2. START JOB INFORMATION 3. ENGINEER DATE 22-MAR-18 4. END JOB INFORMATION 5. INPUT WIDTH 79 6. UNIT METER KN 7. JOINT COORDINATES 8. 1 0 0 0; 2 5 0 0 9. MEMBER INCIDENCES 10. 1 1 2 11. DEFINE MATERIAL START 12. ISOTROPIC CONCRETE 13. E 2.17185E+007 14. POISSON 0.17 15. DENSITY 23.5616 16. ALPHA 1E-005 17. DAMP 0.05 18. TYPE CONCRETE 19. STRENGTH FCU 27579 20. END DEFINE MATERIAL 21. MEMBER PROPERTY **ERROR- IN READING MEMBER PROPERTIES. CHECK DATA FORMAT CAREFULLY.
Plesae upload the .STD file here. you can find steps for uploading file in the attached link.
https://communities.bentley.com/products/ram-staad/f/ram-staad-forum/146556/you-can-upload-std-files-in-bentley-communities
I have been having the same issue. Can you please advise how this issue was resolved?
Can you please upload the file here?
GEB Evaluation.std
There are some .upt files associated with this file. Please send them.
