respected sir,
I am solving a simple supported beam of span 2m. Material = concrete. UDL of 10kN/m throughout the span (2m), but i am getting an error after running analysis.
i am getting an error " **ERROR- IN READING MEMBER PROPERTIES. CHECK DATA FORMAT CAREFULLY."
i am getting this error again and again after adding all the date correctly. Please guide me to correct this error.
DATA:
1. STAAD SPACEINPUT FILE: F:\SProV8i SS6\STAAD\Plugins\tutorial.STD 2. START JOB INFORMATION 3. ENGINEER DATE 22-MAR-18 4. END JOB INFORMATION 5. INPUT WIDTH 79 6. UNIT METER KN 7. JOINT COORDINATES 8. 1 0 0 0; 2 5 0 0 9. MEMBER INCIDENCES 10. 1 1 2 11. DEFINE MATERIAL START 12. ISOTROPIC CONCRETE 13. E 2.17185E+007 14. POISSON 0.17 15. DENSITY 23.5616 16. ALPHA 1E-005 17. DAMP 0.05 18. TYPE CONCRETE 19. STRENGTH FCU 27579 20. END DEFINE MATERIAL 21. MEMBER PROPERTY **ERROR- IN READING MEMBER PROPERTIES. CHECK DATA FORMAT CAREFULLY.
Doesn't allow me to upload the .upt file
Try making a Zip folder.
STAAD_BU_Section.zip
The sequential order of input file is not right. I have edited your file and now it is running good. But, I have noticed that you have used different sets of units all over places. I would request you to review all the units once again in editor file to make sure all are as expected. Please keep the STAAD and .upt in a same folder to run the attached file.
W361503099.zip
Thank you. Correct. Different units have been used. I'll look into it to ensure it's done right.
