Hi everyone,
I would like to know if it is possible to model inverted beam or to apply an offset in a slab in RAM
Thanks.
Gustavo
You can model offset beams and you can offset the slab edge in RAM SS, but I don't know what you mean by an inverted beam. If you are looking to override the beam unbraced length (for a beam that is elevated above the deck for example) you can do that in Ram Frame - Steel - Standard Provisions mode (for lateral beams only).
Answer Verified By: Gustavo Vasconcellos
Thank you Seth. I was talking about a beam that is elevated above the floor. I found that it is easier to do in RAM Concept. Thanks
