I am new in staad pro so please answer this question in very easy language....!
When i did Concrete design with IS 456 many parameters are listed in the design command.....
Can Any one tell me what type of parameters we want to consider in simple residential structure......?
You may check out the concrete design example EXAMP08.STD for the Indian code available within the following folder
For STAAD.Pro Connect Edition C:\Users\Public\Documents\STAAD.Pro CONNECT Edition\Sample Models\Ind
For STAAD.Pro V8iC:\SProV8i SS6\STAAD\Examp\Ind
