We are experiencing STAAD Pro w/RAM Connect crashing when deleting. It does not matter if deleting one item or multiple. We are running version 21000057. Has anyone experienced this or have a resolution?
Eric
It's working OK for me in version 21.00.02.30. I deleted several existing connections from the table with a file I test with.
I have numerous crashes, weird one is when i got error for members with no properties and tried to go to output file to see problem. Then when I reopen it crashes, then I recover and can run it.
Does this pertain to the integration with Ram Connection or just analytical mode? What's your exact version of STAAD.pro?
Seems like an issue that may be specific to the model. Are you working with the file on a network drive? If so, can you please try to copy the file to your local drive and see if that makes a difference. If you still encounter the issue, please zip the entire set of files corresponding to your model and upload it and we will investigate the issue. It would also help if you can let us know the exact steps that lead to the crash.
Instructions for uploading files are available in the wiki below
https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/28129/how-can-i-upload-files-in-the-bentley-communities-forum
