Is there a way to easily print the floor loading from Ram Structural Systems? I have tried printing from the modeler but the hatchings for the different surface loads look the same.
You can use the Report - Map Floor in Ram Steel for this.
This does help identify the different hatching but it does not identify what surface load or the magnitude. Is there a way to get either of these as a label from this option?
The second page of the Map Floor report has the legend with all the details you need.
You can also use the Ram Manager - Post Processing -Data Echo report to list the full load properties for each surface load.
